After work today I'm going to dig into my saw and swap bearings.
Before turning it over should I remove the fence and wings, or is it OK to leave them attached?
(Craftsman belt drive with cast iron wings.)
Leaving the wings on offers a chance to break the bolts that hold them, taking them off, assures that can't happen, and gives you the opportunity to align the wings properly, when you reassemble with cleaner wing connections.... Leaving the fence on offers misalignment, if the top shifts while you're working on it...A flat top, without wings and fence is more stable.... But it's your saw, you have to make the choice!
I left the wings on.
It's upside down now.
But I'm hesitant about going any deeper.
I noticed that the pulley was wobbling.
That would certainly cause my blade to wobble.
For this part of the project I purchased only the bearings.
But I'm wondering if the arbor suffered some distortion from the pulley.
At a minimum I'll replace the pulley.
If that's not enough then I'll tear into it again at a later time.
In the mean time the cuts are adequate for my work.
I can make it "right" (or is that "wright"?) later.
So back together it goes.
If the pulley wobbles, I would suspect the pulley has slipped on the arbor and has done damage. If it were the bearing, it would make lots of noise to be bad enough to make the pulley do that. I'm having a new arbor made now because of that
  • Who's Online   1 Member, 0 Anonymous, 43 Guests (See full list)
    26,008
    Bob44
    Bob44
