collinb Posted April 4, 2015 Report Posted April 4, 2015 So day I got out the saw (Craftsman 113 / 3hp belt drive) to verify that I had done the alignment correctly the other day. Gave me a chance to get the x-y alignment to down to 0.004". I can work with that. But the blade's vertical alignment is way off. I cannot crank it straight vertical. The current error is enough that when I place the edge in the corner of a square I can see light through it. Too much light. So now I'm looking around for instructions on doing this Would make things a lot easier if the cuts were accurate. Quote
Trip Posted April 4, 2015 Report Posted April 4, 2015 If I get this -- you can’t get the blade perpendicular to the table? You can get close to 90*, but not exactly – right? I’m not familiar with your saw in particular, but most table saws operate in a similar fashion, so if I get this wrong, it’s probably not wrong by much… There should be set stops of some sort (usually a threaded rod with a nut to lock the set in place) that are set to 90* and [frequently] 45*. As you crank the miter angle, you should see the trunnion contact the set as you approach 90*. Obviously, you can adjust the set until you get perpendicular… There should be a section in your manual covering this procedure… But it should be something along the line of: Loosen the lock nut, turn the rod to the proper protrusion to get 90*, then tighten the nut to lock it down… There is slop in the threads, so when you tighten the nut, the set will move a bit --- sorry, but it’s a dial-it-in sort of process… If you don’t see a threaded rod, then look for a set screw – these are frequently used on smaller saws… These may or may not be locked-in with a nut… If not nut, then threadlocker might be used… Point is, something will keep it from turning under vibration... BTW: If a threadlocker was used, then you need to re-apply it... You can get a penetrating series (220, 290, etc) threadlocker to apply after the set is… well.. set… Anyway, good luck. Quote
Tpt life Posted April 4, 2015 Report Posted April 4, 2015 http://powertool.manualsonline.com/manuals/mfg/craftsman/11329921.html?p=39 They call it "heel." Makes me laugh. This page starts what you are interested in. The rest follows. Set screws in lock collars on the threaded rod. Quote
Trip Posted April 4, 2015 Report Posted April 4, 2015 ==>They call it "heel." Makes me laugh Heeling --- nautical term (sailing) – tilt from vertical… Quote
collinb Posted April 4, 2015 Author Report Posted April 4, 2015 http://powertool.manualsonline.com/manuals/mfg/craftsman/11329921.html?p=39 They call it "heel." Makes me laugh. This page starts what you are interested in. The rest follows. Set screws in lock collars on the threaded rod. Thanks. I'm becoming accustomed to the to the language now. For instance, on PBS this a.m. one of the sewing shows (before the woodworking stuff) was about quilting a corner, which she referred to the corner as a "miter" -- I think most amateurs would have said "corner" but some people are precise. Quote
collinb Posted April 4, 2015 Author Report Posted April 4, 2015 http://powertool.manualsonline.com/manuals/mfg/craftsman/11329921.html?p=39 They call it "heel." Makes me laugh. This page starts what you are interested in. The rest follows. Set screws in lock collars on the threaded rod. That was for the direct drive. This one for the belt drive. http://powertool.manualsonline.com/manuals/mfg/craftsman/113298721.html?p=39 Still, not exactly right. But the right direction. Quote
Tpt life Posted April 4, 2015 Report Posted April 4, 2015 And now that you repeat it, I remember you already said that. That site listed about 30 manuals for different 113s. Hopefully you can find the digits after 113 for your saw and close in on an answer. I would do as Trip H suggested and dig into the guts, but it is always wise to have the manual handy. Quote
Tpt life Posted April 4, 2015 Report Posted April 4, 2015 http://www.managemylife.com/mmh/pd_download/lis_pdf/OWNM/L0907105.pdf About page 43, easier PDF download instead of needing to page through their website. Quote
Trip Posted April 4, 2015 Report Posted April 4, 2015 ==>Still, not exactly right. But the right direction. It’s a tablesaw, not brain surgery… Just roll up your sleeves and go for it… You’ll learn more by f’ing-up a bit… It’s probably one set screw and maybe a nut (collar) retainer – what can go wrong -- for heaven's sake, unplug it first*... If you’re uncomfortable, tilt it to around 5* off vertical and shoot a photo or three of the trunnion assembly – someone here will walk you through it… *Note: Magnetic switches can 'turn-on' without pressing the 'start' button if the machine receives a 'sharp bang' -- say something drops on the tool or you bump into it... It's never happened to me or anyone that I know personally, but it has happened and is well documented... It's the only safety rule in my shop -- hands in the machine, it get's unplugged -- full stop, no exceptions... Same with changing blades... 2 Quote
collinb Posted April 5, 2015 Author Report Posted April 5, 2015 It’s a tablesaw, not brain surgery… Just roll up your sleeves and go for it… You’ll learn more by f’ing-up a bit… It’s probably one set screw and maybe a nut (collar) retainer – what can go wrong -- for heaven's sake, unplug it first*... If you’re uncomfortable, tilt it to around 5* off vertical and shoot a photo or three of the trunnion assembly – someone here will walk you through it… *Note: Magnetic switches can 'turn-on' without pressing the 'start' button if the machine received a 'sharp bang'... It's never happened to me or anyone that I know personally, but it has happened... It's the only safety rule in my shop -- hands in the machine, it get's unplugged -- full stop, no exceptions... Same with changing blades... That is exactly my approach -- just dig in. I only look for information as a starting point -- finding what matches. It's like I tell new computer/software users -- you're not going to break it so just click around and learn. Of course this is hardware, not software. It can break. And it can cut. So knowledge is safety, imnsho. Tx again. I'm at it now. (and of course it is unplugged) Quote
collinb Posted April 5, 2015 Author Report Posted April 5, 2015 Well, it's "perfect" (given a generous definition of the term). I'll post in another thread some things I learned today. Quote
