jasonjarrard Posted December 5, 2010 Report Share Posted December 5, 2010 need to make a 1/4 in kerf cut for a box joint, wondering if i stack two identical blades in my saw would that be ok and would it work Quote Link to comment Share on other sites More sharing options...
PaulMarcel Posted December 6, 2010 Report Share Posted December 6, 2010 As long as the teeth can be stacked between each other, it should work fine; likely only possible with rip blades. One catch is that two 1/8" blades stacked like you suggest won't make 1/4" groove. The plate of the blade is < 1/8" and as you'll have the blades "plate to plate", with the teeth interleaved on the circumference, the kerf they'll cut isn't 1/4". Quote Link to comment Share on other sites More sharing options...
kesac Posted December 6, 2010 Report Share Posted December 6, 2010 need to make a 1/4 in kerf cut for a box joint, wondering if i stack two identical blades in my saw would that be ok and would it work Probably, if you shim it right. You need a blade with a flat grind, or an ATB+Raker. It might be easier to make one cut on the far side of your cut from the fence, and shim your cut over by 1/8" and make a 2nd cut. There are lots of ways to skin a cat. This is America, you can do whatever you want. Quote Link to comment Share on other sites More sharing options...
TonyV Posted December 6, 2010 Report Share Posted December 6, 2010 Probably, if you shim it right. You need a blade with a flat grind, or an ATB+Raker. It might be easier to make one cut on the far side of your cut from the fence, and shim your cut over by 1/8" and make a 2nd cut. There are lots of ways to skin a cat. Agree, this is the best way to make this cut without a dado stack. Also agree it's best to use a rip blade (flat grind) to make the cut. Tony Quote Link to comment Share on other sites More sharing options...
