harmondreamer Posted October 20, 2015 Report Posted October 20, 2015 Hi, I'm new here, so I would like to ask you a question.I purchased a small workshop recently with the equipment, and now it seems like i need to replaces the motor in the table saw.How to choose it? I mean, what type of motors to consider. Maybe you could help me with it. Im not sure I will be able to choose the proper mtor modelThanks Quote
atlinwi202 Posted October 20, 2015 Report Posted October 20, 2015 Let's start by finding put what saw it is and if there is a nameplate on the motor get that info too. Sent from my SAMSUNG-SGH-I337 using Tapatalk Quote
wtnhighlander Posted October 20, 2015 Report Posted October 20, 2015 A photo or two if the existing motor might help. Quote
a1606myrsclm Posted October 20, 2015 Report Posted October 20, 2015 Why are you replacing the motors? Burned up? Bad bearings? Sent from my iPhone using Tapatalk Quote
harmondreamer Posted October 21, 2015 Author Report Posted October 21, 2015 Yes, the motor burned up. I use DeWalt. I think of taking the baldorhttps://www.mrosupply.com/motors/ac-motors/general-purpose-motors/26523_vm3546_baldor/I also heard a lot of reviews about the leeson, but I do not see the difference.The WEG is cheaper, but I afraid to buy it because there are many doubts concerning their quality. Quote
a1606myrsclm Posted October 21, 2015 Report Posted October 21, 2015 Baldor is a good brand just make sure, everything on your new motor is the same as the old one, i.e. RPM, frame size, hp, voltage (3 phase or single phase). Check the nameplate info, and it should also have a wiring diagram on it, for like high or low voltages if duel voltage or high or low speeds, depends or the motor Sent from my iPhone using Tapatalk Quote
ponderingturtle Posted October 21, 2015 Report Posted October 21, 2015 Yes, the motor burned up. I use DeWalt. I think of taking the baldorhttps://www.mrosupply.com/motors/ac-motors/general-purpose-motors/26523_vm3546_baldor/I also heard a lot of reviews about the leeson, but I do not see the difference.The WEG is cheaper, but I afraid to buy it because there are many doubts concerning their quality. I would be suprised if that would work. I wouldn't think DeWalt made 1 HP 3phase saws. At work we have been buying a few motors from http://www.automationdirect.com/adc/Home/Home Seems to be a pretty good deal. Quote
a1606myrsclm Posted October 21, 2015 Report Posted October 21, 2015 I was thinking the same thing, 3phase?!? Like I said check the nameplate all the info is there Sent from my iPhone using Tapatalk Quote
wtnhighlander Posted October 21, 2015 Report Posted October 21, 2015 Just from the grammar in the original and subsequent posts, I suspect English is not your first language. If you are outside the US, pay attention to frequency as well. While most modern AC motors will certainly operate at 50hz even when designed for 60hz and vice versa, they will not run at the nameplate speed or current. Quote
ponderingturtle Posted October 22, 2015 Report Posted October 22, 2015 Also shaft size. You say get a motor with a 5/8" shaft instead of the 3/4" the pulley is designed for would make mounting the pulley hard. I also wonder if maybe this is a case of needing to replace brushes and not the motor. Quote
wareaglewoodworker Posted October 30, 2015 Report Posted October 30, 2015 The motor on the old Craftsman 10 in contractor saw I use went out on me last spring. After searching for someone local that can fix these motors I opted to buy a new one from Grizzly. They had the best prices I could find and the right specs for the replacement. Replacing a motor is a tough call because the cost is often 1/4 to 1/2 the price of a new saw. In my case the saw belongs to my dad so we split the cost of the motor. So far so good. The new motor runs like a champ. Quote
