estesbubba Posted October 24, 2015 Report Posted October 24, 2015 Also posted this on the FOG.Made my first crosscut on my Roubo today and found out the blade didn't come from the factory calibrated to 90. I broke out a 8/4 jointed piece of hard maple for test cuts. I loosened both ends, moved it back until it stopped, tightened the rear knob then the front. Did another test cut and same problem. Got the supplemental manual out and couldn't find anything on adjusting to 90. Found a little set screw by the 0 indicator and tried that. After several iterations and test cuts my gauge went from 0 to 1/2 but now my cuts are wacky. I'm using a jointed board and Woodpecker's square and here is what I'm seeing. The front edge of the board has light at the bottom (like this /) and rear has light at the top (like this \). I loosed and tightened the knobs and did a few more test cuts and same results. I clamp my track down with each cut. Any ideas on what is going on and how to correct them? Am I not adjusting blade squareness correctly? Searching the FOG it seems like a lot of the TS 55 REQ don't come square and couldn't find easy solution. A lot of people said Festool's solution was to ship it to them which sucks. Quote
davestanton Posted October 25, 2015 Report Posted October 25, 2015 It could be just the weight of the saw body flexing the mount prior to tightening the rear clamp.Try this. Tighten the front clamp when at 90 degrees and then pick the saw up off the track so that there is no weight on it and then tighten the rear clamp. It shouldn't have needed any adjustment but if you have adjusted it a bit make sure that the rear clamp is loose and the saw is unplugged from the power, turn the saw upside down and use a square to check baseplate to blade with the blade fully plunged and make any adjustment to make the front read 90 degrees.I hope this works. It is a common thing. Quote
Guest Randy Posted October 29, 2015 Report Posted October 29, 2015 If it is the actual 0 degree (90 degree) stop which is off, there is a process previously outlined on the FOG which should correct the problem. You can call Festool service also. They went through it step by step with me when I had the problem. Others have had the same problem. Once I reset the stop, though, I have not had this problem so far. There are other posts on the FOG which tell you how to install a set screw to return to the previous model's way of setting the stop, but I'd try fixing it the easy way first.When returning to 0 or setting a bevel angle I would tighten the rear bevel knob first though. Since the main support for bevel settings is in the rear of the saw, once you have the stop set so that the saw truly cuts 90 degrees, I always tighten the rear bevel control knob first as that is the one which governs whether the blade returns to its stop point. When tightening the front knob you need to be careful not to put pressure on the front of the saw or the front will deflect slightly from a true 90 degrees. I have not had further problems after resetting the stop and being careful when I lock down the bevel angle. Quote
Brendon_t Posted October 29, 2015 Report Posted October 29, 2015 Mike sorry your ts is acting up. Are you planning on journaling the build? Quote
