Oil versus Wax
I'm in the process of finishing a island table for my cottage that I have fully constructed from salvaged 3x9 fir timbers.  For the base I used a wire brush to clean up the boards and that is working out fine as it has given a very rustic look.  However for the top I had to cut and plane all four sides of the boards to get a uniform, flat and of course clean surface.  The end product will be a butcher block style top that is about 3 1/2" thick (4x6 is size).  My problem is, what is the best product to finish the top with?  I've looked at Linseed Oil, Tung Oil, combinations of oil and wax but really can't find something that gives me 100% confidence.  The bare wood is very bright so I would ideally like to get some amber color back into in the wood that highlights the grain and hopefully has a soft (i.e. not polyurethane/glossy) finish.  Obviously it needs to have some protectant ability from water and stains as well.  Thanks so much for any advice/ideas you may have. WW
I used Rubio Monocoat on a walnut table base and liked it.  It is a mix of oil and wax with some sort of hardener to help the oil cure.  It leaves a very natural finish, no film whatsoever but seals the wood enough that you can wipe it down.   It is designed for floors so is more durable than tung oil or boiled linseed oil.  it is also easy to reapply when the finish becomes worn.
http://www.hardwoodmall.com/product/rubio-2-part-small/
This thread contains pictures of my table, scroll toward the bottom to see it with the oil finish.
Thanks for those suggestions.  I have never used General Arm-R-Seal.  Do you think this might be a solution as well?
I am a big fan of Arm R Seal.  Despite what the can says, it is a diluted varnish (it is basically 50% polyurethane / 50% mineral spirits).  2 or 3 thin coats will protect the wood without looking like a varnish.  More than 3 coats and you start to build a film, which will give you more protection but also give you a varnished look.
For anything that might serve as a food prep surface, especially if it is end grain, I use a mineral oil / beeswax mixture. 100% edible, absorbs into the wood, easy to apply, and repels water quite well after a few coats. It is available commercially, or you can mix your own. I suggest about a 50/50 mixture, by weight, not volume. Use a double-boiler to melt the wax and mix with the oil.
