estesbubba Posted November 8, 2015 Report Posted November 8, 2015 Get the 52" if you have room just in case you need the extra capacity. Otherwise the 30" will do 99% of the needs. Quote
Bobby Slack Posted November 8, 2015 Report Posted November 8, 2015 How about getting the 30" Wurth the crosscut sliding attachment? Sent from my iPad using Tapatalk Quote
bgreenb Posted November 8, 2015 Report Posted November 8, 2015 You mean 36" right, not 30"? Maybe it's changed in the last couple years but when I bought it the 30" was the inferior fence (not T glide). If that's still the case then you definitely want the 36". (I have 36" and have never regretted not having the extra 15", but I rarely use sheet goods ) Quote
MJ Posted December 2, 2015 Report Posted December 2, 2015 If at all possible, go for the 52". Advantages? Easier ripping of large sheet goods (if you think you need that - I use it frequently). Disadvantage? Much more space to get cluttered up with stuff.I've got an ICS; bought it when the PCS was not available. Very happy with it. Like having the tilt control wheel on the left where the table does not hang out which I think would make it a little more "friendly" than on the right side where the table hangs over the wheel, but that would not be a deal breaker...I don't use the tilt that much...you'll be very happy with either saw. Quote
