Shellac Removal and Cedar Refinishing Questions.
I'm refinishing a c.1950s cedar wardrobe that I inherited.  Don't know how I managed to have so little experience refinishing furniture considering all my years on this planet.  At any rate, I've removed shellac from the top and one side (about 13.5 sq ft) with denatured alcohol, using up the entire pint.  Seemed like a good time to stop and ask some questions.
At what point do you decide you've removed enough shellac with alcohol and move on to the sanding phase?  I made two passes over each side leaving a hazy film of smeared shellac.  I'm thinking sandpaper will get the last of it.  Agree?
Can a heat gun be used to remove shellac from cedar?  I noticed that much of it is bubbled and melted, probably due to being in a hot attic.
After sanding, should the piece be wiped down with denatured alcohol to remove the last of the dust and any residual shellac?  How do you know you've removed all the shellac before refinishing?
I like a tung oil finish.  Is cedar too soft for a tung oil finish.  If it is, what's a good finish coat for cedar.
Are there any other steps; remove shellac, sand with medium then with fine, blow and wipe dust, wipe with alcohol, apply finish?
Thanks.
29 minutes ago, Mike. said:
i think you have the right idea.  Shellac sands quite easily so remove what you can with the alcohol and sand the rest.  Wait a few days before sanding.  this might sound counterinuitive, but you want the shellac to "re-cure" before sanding.  If is not dry and hard it will just gum up your sand paper.
"Tung Oil" is a broad term and about 95% of finishes sold as tung oil are not at all tung oil.  They are usually thinned polyurethane varnish.   Real Tung oils will be labeled "pure tung oil" (which is raw tung) or "polymerized tung oil" (which is treated so it dries more quickly).  It might seem deceiving that a bunch of stuff sold as "tung oil finish" is not tung oil at all.  That is somewhat true, but I will add that pure and polymerized tung oils are difficult to use with good results.   Thinned polyurethane, on the other hand, looks good and is easy to apply.
Thanks for the reply.  I misspoke regarding the tung oil.  It's Watco Danish Oil that I like.  I see it's a blend of varnish and penetrating oil.  Appropriate for cedar?
Can we assume that you mean the outside and not the inside? I would think the inside should have no finish at all for the aroma?
9 hours ago, Mike. said:
Danish Oil will be fine for a light use project.  For something that see heavier use, a few coats of minwax wipe on poly.
Random orbital sander OK?
A wipe on oil/poly works well over shellac as far as adhesion goes so removing every last bit of shellac is not an issue.  What may happen is if you leave a significant spot of shellac the wipe on ply may not penetrate that spot as much and you may see a difference is color (tone. hue) of the wood grain.  You are on the right track.
Thanks, Ron.  I don't know what it is about poly that turns me off.  Leaning towards the danish oil.  I used it some years ago on a floor and was impressed.
