wlburgess Posted February 9, 2011 Report Posted February 9, 2011 Hi all, I am a new woodworker and am very interested in joining the guild. Being a new woodworker I don't have the full compliment of tools yet. What would be a recommended tools needed to complete most of the guild builds. Specifically do you need a planer and jointer? I have a table saw, bandsaw, router w/table and drill press, as well as some smaller power tools (drills, sanders etc). Also what hand tools are required? I would like to join, but if I need more tools, I can wait until I purchase those. I apologize if this list is somewhere on the site, I looked but couldn't find anything. Thanks! William Quote
Bombarde16 Posted February 9, 2011 Report Posted February 9, 2011 Welcome aboard. Sounds like you're pretty much set to me. The router is a fine stand-in for a jointer and the table saw is the supreme multitasker. As for hand tools, even if you're a confirmed Normite, you'll always find need for a sharp set of chisels. But if you've already obtained and are comfortable with the roster of machines described, there's no reason you shouldn't just dive in. Quote
decibel Posted February 9, 2011 Report Posted February 9, 2011 Welcome I think you should be OK with the machines you have now. The current project has a plywood and solid wood version. You could get by without the jointer / planer with the plywood version and if you wanted to solid wood you could order the bell forest kits which are pre-surfaced, but I'd suggest you try to link up with some local woodworkers in your area. I have found most guys are more than happy to help your surface lumber and it's a great way to meet others. I've had a few come by to use my jointer / planer and we I usually learn something from my fellow woodworker if they are a novice (for instance he knew where to find material on the cheap!) Anyway welcome to the site and I think you'll be just fine with what you have. Quote
AMarshall Posted February 9, 2011 Report Posted February 9, 2011 I agree with Patrick and Rob. You've got everything needed, since there are a lot of ways to build the same thing. Welcome to the forum! Quote
woodwhisperer Posted February 9, 2011 Report Posted February 9, 2011 One of the hardest things to advice in the beginning is "what tools to buy". So I usually recommend people start by taking a class or two. In the context of a project, you get to see all the tools you need and what they do. The Guild, is very similar to an in-depth class. So even if you don't necessarily embark on a build, you can see the entire process from start to finish. You will also see alternative tools and materials. After seeing a few projects, you can combine that knowledge with your personal interests, and you'll start to have a nice roadmap for your tool purchases. I find this to be the best way to avoid buying tools you really don't need. All that said, I do my best to provide as many options as possible for Guild Builds. So like patrick mentioned above, you can choose from the plywood version of the current project, or simply buy a pre-milled kit available from Bell Forest Products. Quote
BenMinshall Posted February 9, 2011 Report Posted February 9, 2011 Specifically do you need a planer and jointer? Many hardwood suppliers offer planing and jointing service for a nominal fee when you buy lumber there, so you can avoid the purchase of these machines yourself. A common service you can get at the lumber supplier is S2S/R1E (surface two sides, rip one edge) which will basically leave the board faces smooth and parallel and the edges in a condition ready to rip down on your table saw or band saw. Give your hardwood supplier a call and see if they can accommodate your needs. Quote
