Modifications
A left-handed install would essentially just be the mirror image of the existing bench. I would put the leg vise on the right and the tail vise on the left. The overhang is longer for the tail vise so you would want to make sure that detail is adjusted to the left side as well. And the Benchcrafted plans for the tail vise to include pictures and information that you will need to adjust the vise for left-handed use.
It shouldn't be too difficult though. Just a matter of not confusing yourself or getting parts mixed up. If it isn't too difficult, I'll see if Aaron can include at least one view of a left-handed version in the plan.
  • Replies 54
  • Views 17.5k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • On issue with two tail vises is that you no longer have a clean edge on your bench for croscutting.
  • The split top has a couple advantages I can think of. First, this whole bench is designed to be broken down if needed. When moving, it would be a lot easier to handle a half top. Second and more imp
time is money and i would not ever have the patience or the time to hand plane my top. if you spit it down the middle you have the chance to have a gap that you can clamp projects half way across the table for better stability.
Honestly it doesn't take that long to flatten a top by hand after the first time. Getting the initial flatteness does take some time, subsequent flattenings (every year or two) shouldn't take all that long as it shouldn't go all that far out of flat. Personally I'd say it's quicker to flatten by hand, than it would be to build and use one of those crazy router sled contraptions I've seen folks do. And if you joint/plane the glue ups as you do them it shouldn't require to much flattening from the get go. Stability shouldn't be a big issue if you keep the width to around 24", any wider and it becomes more difficult to use the bench (and a real pain in the you know what to flatten) as it's difficult for the average person to reach that far across.
Any lefties want to talk about modifications for lefties ? Not much written about these modifications but I would imagine the leg vise may be more comfortable on ther other side so clearnace on the right of vise ? Whenever I use a bench , always seems it would be more comfortable with the side or leg vise on the on the other side ?
Marc, do you have info on modifications for left handed people ?
Swap the vice placements, leg vise goes on the right, tail vice on the left. As a lefty our natural inclination is to go from left to right so it's going to be more comfortable swapping the vice placement. I've worked on right handers benches and it's doable, but it's way more comfortable to work on my sinister one :).
