saw dust press
Just a thought with the inevitable cold of winter approaching and all of us that work in the shop thru the winter having to deal with the expenses that come along with heating our shops. Gas, wood burning, what ever it is it sucks. I know that as i pallet up my cutoffs through out the summer, I always think theres no way ill get through all that in the winter and usually by the middle of december i have to buy my first truck load of firewood to heat my shop. to my question, do any of you guys press your own bricks out of saw dust. what is the proces (binding agent, formula). do you use comercial presses or have you made your own. I would love to use a burning fuel that i have an abundence of and thats sawdust. right now i dont know what to do with it. no one wants it for bedding because i use quite a bit of walnut and its expensive to make trips to the land fill. any one have any experience in successfull burning sawdust without a dedicated sawdust burning stove (no cash for that either). thanks guys
I would also like to know. I thought about this bu never really came up with anything to bind it with other than a watered down glue. Maybe something like they make paper mache.
like to know more about this we have tons of sawdust in the classroom and would like to make the best of it.
I wouldnt use glue I would use paraffin wax or even candle wax either way it would be safe compared to the potential toxic fumes related to different types of glues being burned.
agreed. I would think you also want to be careful about what's IN the sawdust - MDF dust, PVC or plastic [for example, from Azek],etc.
There are a lot of tips/articles on using sawdust to make fire starters - mix wax of some type and sawdust. I would use that as a starting point. I think to properly make pellets, you need to have the proper binder, and the ability to press/compress the mix into pellets or some other shape. that might be a little out of the capabilities of a typical shop.
I am curious just how much sawdust (by weight ) you think you have. I think of a ton of wood stove pellets - at about $250/ton - and maybe 90% of it by weight is wood (the remaining 10% being binder) - this is just a guess. It would be interesting to see just how much of a dent in one's heating bill could be made with the sawdust from a typical shop.
ok ive done some more reaserch. And believe it or not it looks like the reciepe is just 80% saw dust/chips, 20% paper pulp, and u add water to make a slurry. then put that slurry into a press then let them finish drying for a couple of days. The problem is the time to make the press. It doesnt look like it is going to take to much time to make. There are tons of plans on the internet and youtube. The problem is im so busy right now i have know time to make and all the comercial presses are like thousands of dollars. Im looking for a simple press like the concept of a can crusher that i can bang these nuggets out. well ill keep looking and let me know if any of you guys find anything. ill also post what i finally end up building if it comes down to that and i hope you will do the same thanks a gain
like i said in the above post, no glue no wax. the binder is just paper pulp and water. Most people are making the paper pulp by putting newspaper in water in a 5 gal bucket and mixing it with a drill and a paint mixer attatchment. then strain out the pulp. this is a pretty cool concept
Interesting - just paper for the binder.
For the press, I'm wondering if some sort of old style sausage maker or meat grinder could be retrofitted with small diameter pipes on the output side, to press the mixture into shape. You could even warm up/heat the ends of the pipes to get the mixture hot enough so that it cures or hardens soon after being squeezed out....
OK, I googled and I found this
www.ehow.com/how_7815267_use-meat-grinder-make-pellets.html
I was thinking more the old style all-metal meat grinder, not a more modern plastic one.
A few articles also mention using waste vegetable oil (WVO) as a binder.
the grinder is a neat idea. ive heard about the vegetable oils also and even wet corn starch . t think the grinder would be a great way to mix the paper/dust mixture thouroughly. Dont know how it would work as a press though. Im trying to make pucks and i think you would need to get more of the water out thaen what a grinder would do. who knows thats why i posted it the more minds the merrier. good idea with the grinder though
