Thick Veneer - How Thick Is Too Thick?
If you glue a thin veneer to a stable substrate (like MDF), the veneer will want to move with changes and humidity and such, but it won't be able to because (being thin) it can't generate enough force to overcome the glue that's sticking it to the MDF. So far, so good.
Now if you glue a thick board to a stable substrate, and the baord decides to move, something has to give. Either the glue joint will fail or the wood will split or some other bad thing will happen. Not so good.
So the question is, how thin does a veneer need to be so that you don't have to worry about movement issues? Can I get away with gluing say a 1/4" thick solid wood veneer to a piece of MDF? How about 1/8"? 1/16"?
Is the outer veneer on hardwood plywood as thin as it is because of wood movement issues, or is it because they're trying to minimize their use of the good stuff?
-- Russ
Ive never heard of any hard evidence that they have to be less than a specific thickness. I think 1/4 is to thick, I generally go 1/8 then pass through the drum sander trying to get 3/32.
Don
I'd guess that, like anything having to do with wood movement, it depends on width (cross-grain). And species.
The idea behind veneer is so that it is so thin that it cant hold enough moisture to allow any measurable change. One reason you want to start with real dry wood because it can shrink real quick but will not expand.
Don
would air dried wood change less then kiln dried because it has more moisture?
Kiln dried wood is more stable. Air dried wood cells aren't as compressed or collapsed in on themselves like kiln drying. So air dried wood moves more.
Isn't why veneers don't move is due to the glue that is absorbed into the wood actually stabilizes the wood?
FWIW, I spent some quality time with Google looking into this further. I never found anything definitive, but the general drift lined up with what dwacker said ... 1/16 to 1/8 is about as thick as you want to go.
-- Russ
you could do a bunch of test cuts that are different thicknesses and then set somewhere to see what they do over time. going to take you a while but it will be good information.
