So I started cleaning up my type 9 #3 plane today and got sanding it at 240 grit and found a crack...well 2 actually. It looks like it has been dropped on it's side. I will give you a link to the picture as I don't think it will show up in a small picture. Not sure what to do about it, if anything. I figured I cant go wrong asking here. My feelings right now are that I will just keep cleaning it up and use it as it will not see a lot hard work, taking mostly light cuts. I am considering drilling a small hole at the end of each crack to stop any further progression of the crack. Maybe in the future have it tig welded. Opinions????
http://s591.photobuc...%3DDSC_5215.jpg
You may want to click on the pic to make it bigger so the cracks can be seen.....thanks
Jim
I think I would go the way you are Jim. Just finish the resto and try it out. A #3 shouldn't see that much hard work, as far as work goes. I think you can still get something out of it.
Thanks Southwood. i was hoping for that answer. I didn't pay much for it. I can't remember each price but I got a 3,4,5,6,7 an LA block and a Sweetheart marking guage all for $115 I think. The guy is not far from me and has a barn full of them, so I can always pop over and buy another if needed.
the gloat pic
Can you tell if the cracks go all the way through the sides of the sole? I agree with Southwood, finish restoring and sharpen the blade and see what happens. For the price you paid for all of those you're not losing any $ if the #3 breaks in half. Besides, you match the plane to the work piece so you'll be using a smaller workpiece with the #3 and use lighter cuts, it will probably be fine. The only bad thing is that #3's are hard to come by.
And I don't think you have a low angle block plane. That looks like a #220 to me which is a standard angle. A low angle is like a #60-1/2. With the bevel up on the block plane, the lower angle of the iron is deceiving. The lower bed angle of the iron and the bevel up actually gives a cutting angle of around 45 deg just like a standard plane like your #3-#7. A low angle block plane has the bed angle and bevel angle equal to about 37 deg.
Restoring planes is fun.
Hi Tim and thanks!
Not sure on the block plane, it is a bevel up though, made by Great Neck.
As for the cracks going all the way through, I have not disassembled it to look. It got a bit chilly here and I wasn't in the mood to be doing wet sanding at right around the freezing point. As said, I will just continue to restore it into a "user" (same with all of them) and see what happens. I may put it on the drill press and put a tiny stop hole at the end of each crack. It's all optional right now. I actually started on the 7 first, but stopped part way through...that is a big chunk of metal to even out...it's probably close enough now.
Then it looks like an equivalent "#220" by Stanley. There were a handful of planes that were made by stanley but branded other companies, Great Neck could be one of them. There is a really, really good website called Patrick's Blood and Gore that explains all of the Stanley planes wonderfully. http://www.supertool...yBG/stan0a.html if you have some free time, I recommed browsing the pages therein.
As far as lapping the sole and sides, I do not wet sand. I use dry sandpaper laid flat on my melamine extension table, hold it with one hand and hold the plane with the other while sliding the plane across the paper. Every now and then, I pick up the paper and strike it on edge to get the cast iron dust off of it. I start with 80 grit and work my way up through 1200 grit. The last several grits aren't necessary for a user but I figure what's another minute or two anyway. All the real work is with the 80 grit to get it flat. Just the other day, I did a #7 and after a few passes on the 80 grit I noticed quite a few high/low spots. I decided to take it the stationary belt sander with 80 grit. Tip, wear a dust mask because there is a lot of fine cast iron dust generated. After the sole was all shiney, I moved back to the 80 grit sandpaper on the extension wing and worked my way up through the grits by hand on the sole and sides. It was so much easier going through the grits once I got it flat initially. Normally, I don't need to use the stationary belt sander.
I also take the time to polish all the screws, lever cap, frog, chip breaker and blade. And I use simple green to clean the japaning and tote/knob then jonshon's paste wax on everything. And I use a stone on the face of the frog and on the mounting points. Here's the before: http://s848.photobuc...nt=IMG_0087.jpg (plane on the right) and the after: http://s848.photobuc...ey%207%20Plane/
Thanks Tim....awesome job on the resto!! I have been to the Blood and Gore page. I think it may be the resource that I used to date my planes. I have been dry sanding mostly, switching to wet at about 240 grt. I am only going to 400 and been waxing them too. I use the scary sharp method (free hand) on the blades as right now it is my only option ( I can get sandpaper locally up to 2000 grt). I have also been taking care of the details like polishing the brass parts etc. I don't have a stationary sander so that is out, I have considered bringing them into a machine shop and having them ground flat, but I will likely just keep with the "armstrong" method..lol. I should get a pic of the block plane as it is done, and making nice shavings too. Strange as it may seem, I have difficulty locating Johnson's paste wax, but I can get "Trewax" locally, which is pretty much the same. I guess no one around here waxes floors anymore. I find if I spritz some water on my TS extension (laminate counter top mat'l) the sandpaper stays put pretty well.
I agree with just continuing the resto and giving it a try as you have nothing to loose and experience to gain. As for drilling a hole, I definitely would not. It will just weaken it more and it will give no benefits. The only thing you can do is have it welded but that is not fool proof either as the heat can distort the iron if done wrong. I would just use it and see, things will probably be just fine. Keep us posted!
  • 3 weeks later...
I have found Johnson's paste wax locally at ACE hardware and Walmart in the floor cleaner section.
Walmart in Canada does not have it, nor Canadian tire. You get funny looks from the kids in there when you ask for paste wax or floor wax. Poor misguided kids don't know anything these days, lol. I get the trewax at my local Home Hardware, great folks and they are from my generation too!
  • Who's Online   2 Members, 0 Anonymous, 68 Guests (See full list)
    26,008
    Bob44
    Bob44
