Dust Collection 101 – what do I need?
I'm glad you set some sort of budget. Without knowing that, it's hard to offer meaningful advice.  I'd also like to ask what your workshop is like.  If it needs to be mobile - say, in a garage which is also used for parking - then that is also meaningful, since fixed ductwork becomes more of a challenge.  I'd also like to know what your expectations are - if anyone in your house has allergies to wood dust, then you want to be far more picky. If you want to just cut back on sweeping, that's another data point.
Since what you're seeing (and will continue to see) is advice from people based on what has worked for them, I'll offer my $.02 here.  I have the Delta 50-760 as well, which has worked very well for me.  I first used it as a portable unit, and then after a while I installed some fixed ducting using 4" S&D pipe to my planer, jointer, and TS, and it worked very well.  I also have a ceiling mounted air cleaner, which - judging by the coating of dust captured on its filter - does a good job collecting the fines out of the air.  I suspect that most of the fine dust was from sanding, and because of that I've started to be more diligent about using a shop vac attached to my random orbit sander.  The one big dust producer I have yet to tackle is my compound miter saw.  I need to build some sort of shroud for it, but I just haven't gotten around to it.  I only use it for rough cuts - my finish cuts are mostly done on my TS sled - so it's not that big of an issue in the big scheme.
If I had to do it again, I'd consider getting one of the mobile cyclone units - they are more expensive, but I think this is an area where you get what you pay for.
If working within a budget, I would also consider getting one of the lower priced 2HP units and upgrading it to a Wynn filter (at least 1.0micron, if not 0.5micron).  Dust collection with a 10 or 30micron bag might help your sweeping a little but does little to protect your lungs.
The delta 50-760 will handle a 5 inch hose. Ditch the y splitter, and buy a 5 to 6 foot length of 5 inch flex hose. Then wheel your way around to your machines. There is a huge difference between a 4 inch and a 5 inch hose connected to that collector. I was very surprised when I switched out my 4 inch hose for a 5. Your tool ports may also require modification.
With a 5 inch hose and wheeled around, the delta meets the requirements set by bill pentz for dust collection (impeller size, hose diameter, and HP). Just be reasonable and don't expect it to be what's its not. It is not designed to be hooked up to long sections of flex hose, or rigid ductwork. The one micron standard bag is good, but can be replaced with a better filtration unit from Wynn.
I'm bouncing back and forth. I don't need to be mobile, I could conceivably plant a unit and run ductwork. My budget isn't severely limited, but I'd like not to spend a fortune.
I have two small children so my goal is to make sure that I keep as much dust out of the air as possible, even though I'm in the garage (and of course for my sake too).
It sounds like the Delta is an inexpensive solution with good collection where the primary drawback is hooking and unhooking it between machines. Not exactly a terrible tradeoff.
The garage isn't used for parking (not cars at least) but now that I think about it I'm not sure I want to work out of that garage forever, so a static duct work setup might not be a great choice anyway.
Right now my priority is safety. If I can get that from the Delta without committing to a more permanent solution that's probably the way to go.
All you can do is what is within your means. Anything helps even a $12 box fan pointed out the door. Even if you decided to hog wild and meet NFPA  standards that osha uses as a the dust collection standard in pro shops your still not going to get great healthy air. Your certainly not going to do it with any of the options that can be installed in a residential environment. Just do the best you can and keep your shop as clean as you can.
Do you wear a respirator?
Not yet, a respirator is on the list as well after seeing the fine coating of dust that's settled over the entire garage after using the planer.
I bought the same one Marc has, and it's fantastic. Check out his video on it. I also did a review on it in the review forum.
Give Grizzly a look. I picked up a G0548ZP a few months ago and am quite happy with it. It's mobile, 2HP, 1 micron canister filter (MERV rated), 6" inlet (came with y adaptor for 4"), lots of suction, etc. only downside is it is loud compared to my previous, much smaller DC.
Adam
