DaBear Posted October 30, 2012 Report Posted October 30, 2012 Guys and Gals, Looking for some advice on purchasing some new bandsaw blades, or perhaps some pointers on my process. I find myself doing a lot of 'strip' cutting for projects like segmented bowls and end-grain cutting boards. Due to my love of my bandsaw (and sometimes hate of my crappy tablesaw) along with trying to save on wood, I find myself doing more and more ripping on the bandsaw, and thus using blades all the faster (or at least, I THINK they are done, all I know is they stop cutting, more on that below). Mostly dealing with maple,cherry, oak,walnut and purpleheart (this, I'm told is especially hard on blades). Usually 2" thick or less, although occasionally more, but generally if it's thicker, it's something like trimming a raw bowl blank, or cutting the back off a bandsawn box, thus relatively low number of 'feet' of cutting. I have a pretty standard 14" delta saw with riser, so I'm using 105" blades. As for feed rate, I try not to overdo it, as I would consider my saw underpowered, although I find the addition of coolblocks helps. I also try to keep a thin coat of lube on the blade itself to decrease any friction loss there. Thus far, I've been using the Lee Valley 'Viking' blades (also known as Timberwolf), and so far, I'm not terribly impressed (although I'm not saying I'm not part of the problem).. One option I'm looking at is a bimetal blade of some sort, so I'm looking for guidance there. Also wondering if there are more things I can do to extend the lives of the blades, like soaking them in cleaner to remove any buildup (mine don't look bad, but I don't know how much buildup is enough to kill performance).. Any recommendations on a cleaner? And by the way, if one of the answers is 'stick with Timberwolf, just keep them clean', that's ok too, I'm not stuck on any one path at this point.. I'm just looking to reduce my overall 'cutting costs'. Another question, other than "it won't cut anymore", is there a better way to determine if the blade is really dull or not? Sorry to ramble, wanted to give as much background as possible.. Thanks in advance.. Da Bear Quote
CessnaPilotBarry Posted October 31, 2012 Report Posted October 31, 2012 I've used many brands, including $30+ premium 105" blades. Many years ago, I went back to plain old $14 Olsen blades, following Mike Fortune's simple band saw tuning articles in "Fine Woodworking". If you're not a subscriber, I'd suggest spending the price of a blade on a FWW online subscription and looking at his stuff. Quote
Vic Posted October 31, 2012 Report Posted October 31, 2012 I just read in another post that Purple Heart, especially, will deposit a lot of pitch onto blades. That may be what you experience as a dull blade. Actually, pitch will cause a blade to dull faster. So, when cutting stuff keep an eye out for pitch and clean it before there is much build up. Quote
wdwerker Posted October 31, 2012 Report Posted October 31, 2012 Clean your blades almost every time you take them off and it is amazing how long they stay sharp. Resin builds up and creates heat which leads to dulling. Lately I have been using CMT's cleaner and a toothbrush in a plastic laundry sink. Router bits and tablesaw blades get a quick clean up when they are taken off so that they are ready when needed. I blow dry my blades with compressed air and give them a spray of Dri-cote. I think purpleheart has a high level of silicates in it like teak does. Takes a sharp blade to cut clean and dulls it pretty quick. Anyone have any experience with those $$$ carbide tipped bandsaw blades? I have a 14" Rockwell/Delta w riser block. Original 1/2 hp motor got burned out by one of my guys years ago. Replaced it with a 1 hp, never stalled it since. Carter bearing guides work great. Quote
DaBear Posted October 31, 2012 Author Report Posted October 31, 2012 Ok, so far, I'm looking to get some Rockler pitch cleaner, along with a couple new blades. I'll see how much better they last with better treatment.. Quote
Ironman50 Posted October 31, 2012 Report Posted October 31, 2012 I have discovered that blades from www.sawblade.com are priced lower from that of the other labels. Despite its affordability, it is uncompromising of quality. Quote
