Plane Blade Sharpening - Straight or Radiused Edge
I picked up some old planes at the antique mall yesterday, a Sargent No. 414 Jack Plane and Stanley No. 4. I am going to get them up into working condition and was wondering what kind of edge should put on them.
I know that Jack Planes tend to have a radius iron in them and Chris Schwarz recommends that Jack planes have an 8" radius to them. I do want to use the Jack plane to flatten boards but also as a jointer until I can get one of those.
I was just planning on putting a straight edge on the Stanley No. 4 but I don't really know for sure if that is what is recommended or not.
Let me know what you guys think.
Also, how do you put a radiused edge on a blade? Do you know of any good videos that go into this. I don't have a grinder just some stones.
Thanks - RJ
I camber my veritas #4 for general smoothing operations. If the blade is left square, you could get "track marks" on the surface of your workpiece.
I use the veritas MKII camber wheel to add the camber. You can do it other ways, including putting pressure on each corner as you hone (count the strokes). http://www.leevalley.com/en/wood/page.aspx?p=54181&cat=1,43072,43078,54181
I have two blades for my stanley #5, one slightly cambered and one square. I use the square blade for jointing with a jointer fence (until I get a jointer plane) and for cleaning up jointed edges from my power jointer. I use the slightly cambered blade for general flattening and smoothing prior to using the #4.
If you use a guide, then light cambers can be applied as franklin pug states - more pressure on the side and count - that's how I do it anyway. Funnily enough I do things the other way round - flat blade for the #4 (but round the corners with a file, that way you won't get plane tracks), and a camber for the #5 for jointing edges. If the edge is out of square, you can use the camber to correct - just move the plane off center a little, otherwise you have to tilt the plane, which doesn't work very well for me.
John
Ok, I think I'll give the Jack plane a straight iron until I get a second iron or a jointer plane. But for the No. 4 should i sharpen the edge like I would a straight iron then knock the corners down or should I give it a camber from the beginning and if so, what radius should it be (I imagine it would be a pretty larger radius camber).
Thanks guys
I knocked the corners off on my smoothers and left cambering to my jack. I don't have a scrub plane yet so I have two blades for my 5. The first is a relatively large radius. The second is pretty small to use for roughing.
I bought the Schwarz video on sharpening in which he describes how to put these edges on your irons. I did it and am quite happy with the results. I have a slight camber on my smoother and a significant radius on my jack. Once I watched Chris do it (several times) it was fairly easy to do it myself although not quick.
Jason I have watched that video a couple times. It can be found on the PBS video website under the woodwrights shop and its name Hand Plane essentials i think
  • Who's Online   3 Members, 0 Anonymous, 49 Guests (See full list)
