TheFatBaron Posted January 16, 2013 Report Posted January 16, 2013 I'm considering buying the ::shudder::Ryobi::shudder:: benchtop drill press from the big orange box. I'm not trying to punch through steel or bore huge holes in wood. Seems to get good reviews and in the end... it's a drill press. It needs to go up and down in a straight line. I'm going to check up on craigslist and my local used tool store to see if they have anything interesting, but are there other features I should be looking for? (Oh, and I don't have much room in my basement, so yes - a 60lb machine that I can move off and on my workbench is preferrable to a 100+lb machine that's pretty much got to stay in one place.) Quote
MatthewCremona Posted January 16, 2013 Report Posted January 16, 2013 I have an earlier version of that drill press. I've had it for 3 or 4 years now. It's a great value. I've never had any issues with it. It does everything I need it to. Quote
kcfandjc Posted January 16, 2013 Report Posted January 16, 2013 I owned that drill press for about a year and sold it just a couple of weeks ago. I never had any problems with it. The only reason I upgraded to a floor model was because I started making some wooden pens and wanted something with more quill travel. Quote
AceHoleInOne Posted January 17, 2013 Report Posted January 17, 2013 Does it have a light? If not, should think about getting one. That's pretty important seeing your lines. -Ace- Quote
Indy Cindy Posted January 17, 2013 Report Posted January 17, 2013 I have that drill press. It works fine, doesn't take up much room, and the light is nice to have. Quote
Chris H Posted January 17, 2013 Report Posted January 17, 2013 I also have this drill press. I am less than extatic with it, but for the most part it gets the job done. My complaints: 1) The quill travel is about a 1/2" short of the longer sections of premium pens. So you have to move the table up part way through the drilling of a blank to get all the way through. I looked high and low for a bench top model with more travel, but to no avail. So just be prepared. 2) The work peice table is very unstable. Again, for the cost it works, but leaves a lot to be desired. 3) Torque is very weak. My dewalt hand drills have far more power. Though, they were probably more expensive. It is not unusal for the drill to lock up on me when drill pen blanks of exotic woods, especially the more dense and oily tropicals. I am sure this is as much my fault as the press. I don't give the bit a ton of time to cool between passes. It takes me 4-5 passes to get through 2.5-3" pen blank. In summary, all these complaints are relatively minor annoyances, and you can work through them all. It does get the job done, at a very low price. I will likely move up to a floor stand model though, once I have a bigger shop. Quote
TheFatBaron Posted January 17, 2013 Author Report Posted January 17, 2013 Chris - thank you for the criticisms. I'm not getting into turning anytime soon - this is mostly for nicer, more repeatable pilot holes and occasionally using forstner bits for hogging out mortices or larger recesses for flush mounts - though I do occasionally work in really tough woods like jatoba or black locust. The toughest drilling I've done lately was using a 1 1/2" forstner bit to drill a hole through a 1 1/2" piece of walnut, which was enough to stall out a Delta floor model if I rushed it. Good to know that may (will) be an issue to watch on this one two). I was planning on making a basic fence anyway, since all of the standard drill press bases are pretty tiny. My local used tool shop got an 8" Craftsman benchtop in, but it's not a significant savings, and it's a smaller, less adjustable model. I'll probably watch craigslist for a while, and if nothing interesting pops up there, pick up the Ryobi. Quote
arcwick08 Posted January 18, 2013 Report Posted January 18, 2013 I've got a model of similar size, stroke and HP. My advice would be to save up and get one of the larger bench top models. I have an awful time drilling with forstners or circle cutters, not enough power :-( Quote
tdale51@yahoo.com Posted January 18, 2013 Report Posted January 18, 2013 I've had a Ryobi drill press for about 3 years now. It's the 13 inch model not the 10, but it's done everything I've ever asked it to do. Wood magazine reviewed it a few years back and had good things to say about it. Quote
