Arm-r-seal over water based urethane?
Can I apply arm r seal over general finishes water based enduro pre cat urethane? I would be wiping on the arm r seal with a cloth over a hvlp sprayed pre cat urethane. Would there be any adhesion issues or any other problems with this approach?
Why would you want to do that ? GF Pre Cat Urethane is a great finish . I've heard of people doing this the other way around , using ArmRseal first then finishing with GF PreCat. If you did this you would need to let the ARS cure , they say 48 hrs  but I think I would let it cure a little longer do to it being and oil base finish .
BTW Hey Neighbor  ! You should stop in live chat sometime , there's a bunch of us from the area that hang out in the chat room and get together from time to time .
 Rregards
 Jerry
Lol. That didn't take long. Somehow I knew "why would you want to do that?" would come up.
I have a garage shop and I think the cold is keeping me from getting a smooth spray finish with the precat. I'm by no means a good sprayer but I had good results earlier this year with the product when it was warmer. So my thinking is if I can't get a smooth finish with the precat I will sand the final coat smooth and then wipe a coat of ARS for a final coat. Not that I am going to do that but I just wanted to know if it is possible.
Let me know the next time you have a little get together.
Try warming the finish before you spray it , either bring it into a warm place or heat some up on a hot plate . I leave mine next to my heater , and lately because of laziness I've been rolling my pre cat with a paint roller . You might want to try thinner coats too .
We have put the gun in a bucket with warm water to keep the finish from being cold. I use a turbine HVLP to spray. I start the turbine and let it run untill the air coming out is warm . We also use a couple of oil filled electric space heaters to keep the spray area temperature above 65. They act like radiators, no fans or air flow to collect dust. You want the wood to be sprayed not to be cold either. Thin coats will behave better in these conditions.
If you use a compressor to spray maybe a hose coiled in a bucket of hot water would help?
I learned to avoid switching between oil and water based finishes if at all possible. When I have to I put a barrier coat of shellac between them.
I actually spoke with a rep from GF today and he said it would be ok to put the ARS over the pre cat but he recommended heating the pre cat up and trying to get a better finish with it first. He said I could even put some in a cup and stick it in the microwave for a few seconds. I'll try it out tonight and see what happens. I'd really like to be able to start using all water based products but haven't quite found one I think looks as good as an oil.
I had similar issues with a different water based product. At certain times of the year, even the warm HVLP air wasn't enough.
I came up an old Crock Pot, added some water, and kept the finish containers in the warm water. Someone gave me the pot, as it's missing one handle. It doesn't seem to get hot enough to get the finish beyond warm, so it works great!
I also found that using extra 500w work floods helped keep the surface being sprayed warm enough.
Just to give an update, I finished the project and stuck with the water based pre cat urethane. I did heat it up in the micro for about 20 seconds. I also use a electric space heater in my shop so I hung the gun a foot or two in front of the heater until it was pretty warm then dumped in the heated pre cat. Wow, what a difference. Once the gun and finish were heated it flowed beautifully. I could tell when it started cooling off by the way it was spraying and would just put the gun back in front of the heat for a few more minutes. I'm very happy with how it turned out.
A good rule of thumb is 10 degrees = 10% viscosity change to a a degree. Warm, meaning just over body temp will do alot for waterbased finishes. It lets you lay down more finish in much less time vs thinning.
Don
  • 26,009 Total Members
  • Joseph b Newest Member ·
