Sawstop Questions: Dado Blades, Riving Knife, Power
does anyone own a sawstop (more specifically the 3hp 36" professional) and know...
Can I use a 6" dado blade (can I bypass the safety system in order to do so)
Do I HAVE to run the saw with either the riving knife or blade guard
Once the main power is turned on, is it customary or ok to keep it on the whole time your in the shop and just use the paddle switch? Then turn main switch off at end of the day.
Thanks
-Adam
I don't own a SS table saw, but I know you can override the saftey feature for specialty blades.  I actually saw this saw demo'd at the local Rockler last weekend.  They dropped in an aftermarket Dado, I think it was 8" though, but I doubt that would matter.
Thanks
-Adam
1.) I don't know, but I'll try tonight.   There is some sensing going on during power up self test, and I've been told 7 1/4" blades do not work with an 8" cartridge, so I'm guessing it won't work.  I'll let you know.
2.) NO.  The saw works with either, both, or none.
3.) Yes.  Mine, another local shop, and the three at my local school, are all operated this way.  Turn the master off when changing blades and brakes, the saw will self-test when you finish the changeover and power back up.   You can leave that switch on as long as you like.  There is a third power switching device on my ICS, on the lower left side of the saw, a rotary disconnect.
I do not own a sawstop, but the demos I have heard, you must use an 8" dado blade.
Here's the skinny...   I was always told it wouldn't work, and the manual says it won't work, but I've never tried myself.  Today, I tried it...   When the saw is powered up, the self test fails with a "Brake Too Far From Blade" code...
With the code set, the saw cannot be started, even in bypass mode,
The final answer is... NO.
I suggest you sell your 6" dado with your old saw...
Thanks to all for the input, especially Cessnapilotbarry for taking the time to experiment for me. Lastly, would you reccomend this saw? Good quality, fit and finish? How would you say it compairs to some of the other top manufacturers?
I spent about a year and a half agonizing over which table saw to get and I was within 12 hours of getting a Unisaw before I settled on a a 36" SawStop PCS. The only reason was that the Sawstop had a slightly smaller footprint (around 2" front to back I seem to remember, and 2-3" in with) that made a more convenient fit in my shop, particularly for moving it around. The fit and finish is excellent, the design and build quality is remarkably solid, and it's performance is excellent. Even the stock blade, while not competitive with a WWII or Glueline, is a decent blade that will last you well past the "getting started" phase. Lastly, the instructions, support, and customer service, are excellent and probably the best that I've encountered for a commercial product in the last 25 years. About the only negative comment I have is that the stock miter gage is true crap, almost tragic.
A buddy of mine has a Unisaw (3-4 years old). All of the same comments apply except about the stock blade and the instructions.
A brief amount of research will reveal that most people will say comparable comments about a PM2000.
My observation is that once you get into that class of machine the difference start showing up in things other than performance. You'll find it in table size or the mobile base, or accessory storage, the stock fences, dust collection, left or right tilt...things like that. Find the one that has the right mix of stuff other than cutting wood and there you are.
So, yes, I recommend the 3HP SawStop PCS with a 36" fence to anyone who wants one.
I have the 5HP "industrial" cabinet saw. If anything happened to it, I'd go out and buy another one tomorrow.
One day they will pull this table saw from my cold dead hands.
I paid near 4K for mine almost 7 years ago. I ordered it with a 52" delta unifence and side table.
I ordered it from Acme tools who brought it to my shop and set it up for me.
I have not suffered even one second of buyer's remorse on this purchase.
I've gone through nearly a half dozen router tables and can't seem to "get it right".
But the table saw, that one I'm am positive I "got right".
I use the big 5HP cabinet saw as well (at the community woodshop I'm a member of). I'll echo Chet's comment above. If I ever buy a house with enough space for a dedicated shop (or I get a garage/shed built at my current home), I will buy a Sawstop, no questions asked - especially with my little one running around hopefully being curious about what I'm doing.
I have a 3HP SawStop Industrial Cabinet Saw.
For many years, I was extremely happy with my 3HP General 650, a well-regarded, powerful, very accurate, cabinet saw, except it didn't have a riving knife.  I had the opportunity for extended use of three ICS examples at a local school, and was extremely impressed with everything about them.  I owned two other saws before the 650, and had planned the 650 to be the last saw I ever purchased.  I have personally used examples of every cabinet saw currently made.
After exploring the costs and effort of adding a true riving knife to my existing saw, I put my 650 on Craigslist for an "I don't really know if I want to sell it" price.  It sold in two weeks...  ;^)
13 months later, I would recommend my SawStop saw to anyone, and would replace it in an instant if it were stolen.  Even though I've never had a table saw accident that injured me, my wife was thrilled to spend money on the new saw.
  • 2 months later...
Have the SS. Just used my old 6" dado set. You need to buy the dado specific cartridge. Also get the dado insert plate.
Take it back. I have 8" dado.
How did you do this?  Is there now a 6" SS cart?
There are situations where I would love to use non-standard sized blades, but my saw will not pass POST.
Chet - they really came to your house and set it up for you?  Is that a normal service that Acme Tools provides, or did you pay for that?
They really did.
The SOB is heavy too. They brought 4 guys to carry it in and 2 of the stayed to set it up.
The only thing they will not do is wire your 220 for you. But I did that part myself with out difficulty.
Yes, That is normal for Acme tools here in Des Moines. No charge on big ticket items.
They also let me mix and match my saw and my fence. I've heard other places won't do that. But I can't confirm. I can tell you they told me it would be a wash between the SawStop fence (Which is a good fence btw.) and the Delta Unifence which I'm addicted to. The true beisemeyer (SP?) was about a 90 dollar adder as I recall.
Ahhh ok, so you're local to their retail store.  That makes sense.  I'm looking to make a saw purchase in the next year or so - I'll start looking at retail stores around me and see if they'll provide the same service.  Setting up my Grizzly jointer was a real PIA and I would've been very happy if someone came over to do it for me!  I don't mind tuning tools myself, but moving around all those heavy parts and putting it together I could definitely do without.
I had my heart set on the PM2000, but I've been wavering ever since reading all the sawstop threads on this board.  I'm definitely more on the fence now.  I'm planning to go to the next demonstration they have at my local Rockler to see it in action.
