Alan G Posted February 10, 2016 Report Share Posted February 10, 2016 Good morning- I am trying to finalize the setup of my air compressor. I plan on using it for spraying with an HVLP. I was curious what those of you that spray with a compressor use for your filter / dryer / reg setup. In my research I have found everything from a simple filter dryer reg combo to a very elaborate pipe setup with multiple moisture traps. Any advice would be appreciated. Quote Link to comment Share on other sites More sharing options...
wdwerker Posted February 10, 2016 Report Share Posted February 10, 2016 Before I went to a turbine HVLP system I used 2 filter/dryers .One at the compressor and another 25 ft away in-line, then a hose from there to the spray gun . It was amazing how much moisture the second unit captured . With a turbine system the air is quite warm and I haven't had any moisture problems. Quote Link to comment Share on other sites More sharing options...
Trip Posted February 10, 2016 Report Share Posted February 10, 2016 Here's a resent thread on air compressor setups: Note: spraying with central air adds a good deal more requirements than just driving a pin nailer... It's why many go with a turbine setup. 1 Quote Link to comment Share on other sites More sharing options...
Alan G Posted February 10, 2016 Author Report Share Posted February 10, 2016 Thanks for the link to that thread. Good info in there. Quote Link to comment Share on other sites More sharing options...
