Boiled Linseed Oil Questions
I decided that I am going to use Boiled Linseed Oil on the bench I am building. I have not used any finish other than polyurethane so I am not familiar with all of the details with this application. I have done some research on it but I would just like to confirm what I have found.
As for the preparation of the bench for finishing I am planning on sanding up to 220 grit, raising the grain, and sand again with 220 grit. Most of what I have read suggest sanding up to 320 grit but my thinking is that it is just a bench that will get scratched and dinged so going to the higher grit isn't necessary. Is this a fair assessment on my part?
Now with the application of the boiled linseed oil I intend to flood the surface using a foam brush. Let the wood soak in the oil for 20 minutes then wipe off the excess. But I have seen people suggest letting the oil sit for as long as an hour before wiping it off. What do you all recommend for a soak in period?
I would then give it a day between coats and then I was going to sand down any bumps with 0000 steel wool. I am not sure how many coats to apply though. I was thinking from at least 3 coats but how many coats would you suggest?
One source that suggested you allow a month for the finish to cure before any hard use but that seems like a little much to me. I know that the oil takes longer to cure but I was thinking that it might take a week. What is your experience with the cure time for boiled linseed oil?
Thanks
I used BLO on my bench...
There's no need to do all that sanding...the smoother your bench is, the more your workpieces will slip and slide around, and you don't want that.  You could really just flatten with your planes and call it good enough, but if you do sand I wouldn't go any higher than 120...it's not a piece of furniture, it's a tool.  You're looking only for protection, not beauty.  A butt ugly bench that holds your work is better than a pretty one that's slick as glass.
As for application, flood it on, and keep flooding it on until it's not drinking anymore.  Then give it 15 or 30 minutes, doesn't really matter, and wipe up the excess.  Depending on what kind of wood you used, the oil may weep back out as it dries for several hours, so keep an eye on it and keep wiping any droplets that come to the surface.  They'll turn tacky if you don't wipe them up.
I let my first coat dry for two or three days, then applied another.  And I only did two coats...it's just a bench.  I thinned the BLO a little bit, maybe 3:1 with mineral spirits because the stuff is thick as snot.  It's easier to apply and I think it penetrates a little deeper when thinned, too.
It'll take days to weeks to fully cure.  Screw it...I was working on mine as soon as it was dry to the touch.
Oh, and be sure to properly dispose of your oily rags.  BLO is very likely to combust if you don't.  Don't ask me how I know.
Do what the man says, his bench is epic
+1 on the oily rags! My in-laws house caught on fire due to spontaneous combustion, different cause than oily rags but the Fire Marshall told me to always spread the rags out flat or hang on a metal railing outside until dry then throw them away.
I use Watco Danish Oil, dries a little faster & seems to have the same results. Couple of coats is plenty.
Thanks guys!! It didn't even cross my mind about the disposing of the rags
  • 26,009 Total Members
  • Joseph b Newest Member ·
