This might seem like an elementary question but I am about to use my OF 1400 for the first time. I have only use a router a couple times before and that was about three years ago, so using one if very new to me. I want to use a 1/2" flush trim bit with the bearing on the bottom. I want to flush up the top of an outfeed table but not exactly sure how its supposed to work. I want to make sure I do it right and don't hurt the tool or myself :D
I have included a couple pictures which may help.
The cut of the bit is going to match the path of the bearing.  If you want the top edge to be straight and parallel to the solid base you're going to need a straight flat surface to reference to.  Those bore holes are going to be an issue.  Direction of travel is important as well.  I'm trying to think and it's hard to do without having a router in my hand but I'm pretty sure you need to go anti clockwise.
After taking a second look at the picture, you may want to use a straight edge of some sort and have a top bearing flush trim bit. (Pattern Bit) The thin 1/4" sheet of MDF is probably the "deepest" and the bearing probably wouldn't fit in the gap. You want the bearing riding on the "deepest" part to bring everything else down to that point. But using a flush trim bit isn't much different than other bearing bits. Left to right, and small passes.
Thanks for the replies, I don't have a top bearing bit, which would have made the most sense.  Byrdie, I was going to stay above the bore holes and reference the bottom piece of MDF. I ended up finding an easier solution; TS75 and a guide rail. I just wanted to give the router a try and figured it was as good a time as any but I guess not.
  • Who's Online   2 Members, 0 Anonymous, 49 Guests (See full list)
