Fitting Cabinet Doors
Hi All,
I recently purchased a home and decided to stain the cabinets. I took all hinges off of doors and framing, and stained away! I found the same butt hinges, but different color from the original which I figured would be easy to install. I've installed some doors with no problem, but I am running into problems when I have to put two cabinet doors side by side. Some are rubbing, not closing, or fitting correctly. Is there anyway to adjust these hinges:
http://www.homedepot.com/p/Liberty-Self-Closing-Full-Overlay-Hinge-1-Pair-78557/202066905?N=ar4i#.UXYMXMqaRq0
Any suggestions or tricks which will allow me to make these cheap things work would be great!!!
Thanks,
Jake
There may be some tolerances that were not be very exact in the manufacturing. You may be able to mix the hinges around and get them to work. Otherwise it looks like you need to adjust the mounting position on the face frame. You will probably have to fill the holes and drill new pilot holes. The distance from the mounting holes to the barrel of the hinge is probably slightly wider than your originals.
If you fill the original holes with toothpicks dipped in yellow glue you can then drill a small pilot hole just far enough over to give the door the space it needs to clear.
I just jam the hole full and cut them off flush with my knife.
If you need to go into holes that are very close wdwerkers tip is great.
The hinges are cheap but how careful are you being with positioning things? I must admit I have never seen these hinges before but I think I would tackle it like this.
Forget the old screw holes. Screw a pair of hinges on to one door only (no point wasting time on the others if this does not work) dropping them just low enough to screw into new timber but not so low you show the old screw hole
Mark the frame that will hold the door so the overlaps of the door are even, level and square (if you can't mark the frame apply a bit of masking tape and apply a pencil mark).
Screw the door in place and review. Look for how and why they might be binding, shim and adjust if required. If the hinges are really bad fine get some more. If it works, happy days!
Just as a side point do you guys call the hinge described a butt hinge? I call this a butt hinge
Thanks for all the replies! Particle board: are the hinges you linked adjustable? What would make them a lot better? They are only about a buck more than what I paid.
Cheap stamped hinges are usually bent all messed up. The hinges you linked to have circular screw holes, replacement stamped hinges have oblong holes for adjustment. We used to do lots of reface work back in the 80's and found its easier to start from scratch. Dismount all hinges fill all holes with dowels. The stamped hinges varied to much even from hinge to hinge. The rockler hinges are going to let you adjust the door reveal. If your starting from scratch yours would have been fine.
  • 26,009 Total Members
  • Joseph b Newest Member ·
