Chuck Melton Posted April 29, 2013 Report Posted April 29, 2013 I am finding as a I am practicing with the jointer I have, that almost every piece of wood I joint ends up with one end of the board being significantly thicker than the other (1/4 plus along an 8' board). I am fairly sure I am doing something wrong, my jointer is about 40" long and I had been running it without an additional infeed roller (I just picked some up), so it may be related to me not having great control of the board during the first few feet and having to apply extra force to keep the board from tipping back. I am also finding that it is taking a ton of passes to get a smooth surface. I am taking relatively light passes (1/32 ish). I don't have a precision straight edge to take to the machine but it's pretty co-planar from what I can tell with a large framing square and a level. Any advice is a appreciated. Quote
Trip Posted April 29, 2013 Report Posted April 29, 2013 classic setup issue -- the 'thicker on one end' is the give-away. Marc has a video on jointer setup -- from memory 'Jointers Jumping' or some such. I think it's on the free site or downloadable through the podcast. i could be wrong and it may be a guild-only video -- if so, then quite frankly it may be worth your while to join just for the setup videos... Quote
G S Haydon Posted April 29, 2013 Report Posted April 29, 2013 Hi Chuck, I'm not used to smaller machines so use my advice with caution! On a jointer if the wood is tapered it would normally be due to the out feed table being too high. Drop it too far and you will end up with bump as you push the last bit over the blades. With our old jointer I used the following method, bear in mind though it was a very big industrial jointer. Isolate the jointer from the power supply when making these adjustments . It was known a 6mm hardwood throw. I took a straight piece of hardwood about 12mm thick and 25mm high and and drew two square lines 6mm apart across the 25mm width. Resting the hardwood on the out feed table I lined up the first line with edge of the out feed table closest to the cutter block. I then gently rotated the cutter block in it's normal rotation, when the blade came into contact with the wood it would lift the wood forward and then when the cutter ceased being in contact he wood would drop. Ideally the second pencil line would then be where the first one started. If it was less I dropped the out feed if it was more I raised it. Alternatively just wind down the out feed very gradually and do trail cuts until it is not tapering and not leaving a bump. Hope that helps chuck. Quote
stahlee Posted April 29, 2013 Report Posted April 29, 2013 Classic outfeed is too high. Haydon gave you some good advice and I'll keep mine simple. I'll get my outfeed table level with the blades and then slightly lower the outfeed table. Only a hair, then adjust as needed. chris Quote
mking1 Posted April 29, 2013 Report Posted April 29, 2013 ¼ inch difference between ends on an 8 foot long board might not be all that bad depending on how twisted, bowed or cupped it started out. I usually rough cut lumber on a little longer than the finished sized before I start the milling process. This tends to lessen the amount of material removed necessary to straighten the board. Miles 1 Quote
dwacker Posted April 29, 2013 Report Posted April 29, 2013 Do your testing with a board that is the same length as your jointer infeed table. If it cuts wedges adjust tables if it doesnt cut wedges with short boards then your tables are fine. 2 Quote
Chuck Melton Posted May 1, 2013 Author Report Posted May 1, 2013 I did the wood test as GS suggest and the blades are barely catching.the wood at all. Oddly, this jointer doesn't have an adjustable outfeed table, the manual suggest adjusting the blade height. Thanks for showing me the way guys! Quote
G S Haydon Posted May 1, 2013 Report Posted May 1, 2013 That sounds hard work Chuck. How easy is it to adjust those blades? Quote
