Chet Posted January 8, 2018 Report Posted January 8, 2018 You might check ereplacmentparts.com for the wrench. Also you might be able to get some help on vintagemachinery.org Quote
Stuart Elder Posted January 9, 2018 Report Posted January 9, 2018 Thank you, I will try to make a wrench with some of the tempered material I have. I have plenty of knives, it came with four sets. Quote
Stuart Elder Posted January 9, 2018 Report Posted January 9, 2018 ereplacmentparts.com didn't have it listed anywhere, most of the wrenches were not available. I'll try to make one. Quote
Tom King Posted January 9, 2018 Report Posted January 9, 2018 I believe it was Home Depot where I found a 5/16" wrench that was thin enough without grinding, but I just did a search on ebay for "thin 5/16" wrench", and found this: https://www.ebay.com/itm/5-16-Hardened-Thin-Wrench-2-WRENCH-SET/192340966980?hash=item2cc86a3e44:g:XvUAAOSwqu9U~Qrv It's been 40 years, at least, since I ground down a wrench to use with the Rockwell jointer, and I can't remember if it was 5/16 or 1/4". My other jointers use 5/16's, but can't really go on that. I couldn't find a thin 1/4 on ebay. An ignition wrench might work if it's 1/4". This one would be nice to have with the different angled ends: https://www.ebay.com/itm/Armstrong-1-4-Open-End-Ignition-Wrench-15-X-80-Deg-Offset-27-908-nvr-used/372141235448?hash=item56a5589cf8:g:Cv0AAOSwiA9ZZDqR Quote
