hammer1 Posted May 18, 2013 Report Posted May 18, 2013 so i have a older craftsman table saw with upgraded extentions and fence system that a i am very pleased with, it as the origanal 2hp motor on it 3400 rpm, i recently aquired a 3 hp motor with 1700 rpm my question is would it be adventages to change to the 3 hp ? i am thinking maybe i will loose on the rpm bot gain on the torque the 2 hp bogs down if i am ripping large stock like a 4x Quote
dwacker Posted May 18, 2013 Report Posted May 18, 2013 Put the right pulley on and your good. Dont just slap on the 3hp motor with wrong pulley. Quote
tim0625 Posted May 18, 2013 Report Posted May 18, 2013 First order of business.....FIRST POST!!!! WELCOME TO SPAGNUOLO'S WIDE WORLD OF WOOD WORKING!! Good place to hang out, ask questions, and get inspired! Wow...I've just hit my 500th post....moment of silence............................. Someone with some more knowledge of motors probably needs to chime in also; but I'm thinking off of the cuff that if you fit the 3HP motor with the pulleys to get the desired the 3400 rpm, that maybe you will need a larger torque motor than the 3HP or either a 3HP motor that is designed to run at 3400 rpm. In this case, you gain one more HP but you're increasing the load on it, by getting more rpms out of it. it seems like its performance (actual power to cut through thicker stock) may be about the same as the 2HP motor that you have now at its (designed) 3400rpm? Quote
Tpt life Posted May 18, 2013 Report Posted May 18, 2013 Again, wait for a motor guy to answer for real but in response to Tim, you size the pulley to allow each motor to run in its optimal range while getting the correct rpm for the arbor. The HP will show as an increase in torque. HP is the movement of mass over time. If you lengthen the time by double and still rate at 3 HP then the motor should have tremendous torque capability. Quote
dwacker Posted May 18, 2013 Report Posted May 18, 2013 First order of business.....FIRST POST!!!! WELCOME TO SPAGNUOLO'S WIDE WORLD OF WOOD WORKING!! Good place to hang out, ask questions, and get inspired! Wow...I've just hit my 500th post....moment of silence............................. Someone with some more knowledge of motors probably needs to chime in also; but I'm thinking off of the cuff that if you fit the 3HP motor with the pulleys to get the desired the 3400 rpm, that maybe you will need a larger torque motor than the 3HP or either a 3HP motor that is designed to run at 3400 rpm. In this case, you gain one more HP but you're increasing the load on it, by getting more rpms out of it. it seems like its performance (actual power to cut through thicker stock) may be about the same as the 2HP motor that you have now at its (designed) 3400rpm? We don't care about the speed of the motor. We want to maintain the rim speed of the blade to get the proper chip load. If you cut the blade speed in half the the blade performance falls on its face. In the end we are looking for an arbor speed of 4000 to about 4500 with a 10" blade. Your going to need some oddball pulleys to get the needed arbor speed. Sounds more like a compressor motor rather than a high rpm machine motor. Quote
hammer1 Posted May 19, 2013 Author Report Posted May 19, 2013 thanks for the responces, i am a carpenter and i am remodaling a restaraunt and the motor came off of a large ac unit , couldnt i just use the same pully off the origal motor? its 2 in. in diameter Quote
woodbutcher74 Posted May 19, 2013 Report Posted May 19, 2013 Like some of the other guys, I'm not a motor guy but I think it would be less hassle to get a thinner blade to cut your thicker material. They require less HP and make nice clean cuts. I never have been one to modify things. Somebody with a lot more knowledge than me designed the saw and when you modify it there as usually backlashes that you never dreamed of show up. Just my experience! Quote
Tpt life Posted May 19, 2013 Report Posted May 19, 2013 Hammer, the same pulley with half the motor RPM is going to equal half the blade RPM. This will affect cut and is a bad idea with circular cutting saws. Quote
Levi Rathje Posted May 20, 2013 Report Posted May 20, 2013 The pulleys drive- driven ratio would have to be changed to compensate for the motor that's only turning half the speed. To change this and get the speed you need you are going to to have to increase drive size and possibly reduce the driven side(arbor). This will in effect make the motor gearing higher but it comes with the trade off of power loss through mechanical advantage. Optimal performance is 1:1 ratio for power and torque. Just imagine it as a 10 speed bike same effect just different power transfer mechanism. Quote
hammer1 Posted May 21, 2013 Author Report Posted May 21, 2013 thanks for the responses. i think i am going to try it anyway it is just 4 5/16 bolts to remove and reinstall , simple easy to get to i will see how it preforms if it dosent i will switch it back to the original when i have time and the energy i am usually to tired from work to play in the garage .maybe this weekend Quote
