baok Posted June 3, 2013 Report Posted June 3, 2013 I have an old eggbeater drill of my Dad's that I remember playing with as a child. I've been using it occasionally. Just recently the jaws have been flopping around loosely. I unscrewed the chuck completely from the shaft and a spring fell out which was all twisted and kinked. I couldn't get the jaws out. Any idea if this can be taken apart and repaired? I couldn't figure out how to get the chuck apart even if I could find a spring. Quote
baok Posted June 4, 2013 Author Report Posted June 4, 2013 Well, clearly it is possible to get the chuck apart - I tried it already but apparently more muscle is required. I'd just buy another one if this wasn't sort of a family heirloom thing. I guess that shouldn't stop me from still buying another one... Quote
G S Haydon Posted June 4, 2013 Report Posted June 4, 2013 If it's a nice family item perhaps a local general engineer could help you out. Always hard to part with items that have strong memories attached. Quote
Admiral Posted June 8, 2013 Report Posted June 8, 2013 Greg: Make of the drill would help, so would pics of the bottom of the chuck. Let's pretend its a Millers Falls. Unscrew the chuck from the drill post. Look at the bottom, there should be two grooves on either side of the hole. There is the lower part of the chuck that unscrews from the upper part, maybe 3/8" thick. Wrap the top part of the chuck in some leather so you don't bugger it up, and tighten it in a machinist's vice, then if you have a split nut screwdriver, try and unscrew the bottom of the chuck. If no spit nut driver, then take some vice grips, again with leather or heavy rag to prevent scarring of the chuck, grip the lower portion and try and unscrew. If no joy, then soak the chuck in some penetrating oil for a few days (or a mix of 30% to 70% kero/automatic transmission fluid, which makes a good penetrating oil) and try again; if no joy, repeat..... When it does come apart, take careful notice of how the jaws are set in the chuck, not all are the same, and how the springs sit between the jaws. You can't find suitable replacement springs, I've tried and failed. What you can do is get some wire instrument strings (think mandolin, banjo, etc.) about the same diameter of the spring you've broken, and wind your own. Takes a bit of practice, but I've done it several times. Good luck. 1 Quote
