adambaum Posted June 9, 2013 Report Posted June 9, 2013 I'm stuck on clamping the paper on the inboard side. Where is the actual clamp point? Do I feed the paper towards the back? Front? Center? I just can't seem to get it inside the clip. Adam Quote
adambaum Posted June 9, 2013 Author Report Posted June 9, 2013 Of course, once I ask for help, I finally get it clamped in. Only took me about 45 min in total. Quote
AceHoleInOne Posted June 9, 2013 Report Posted June 9, 2013 I have a Delta sander not sure the clamps are the same......? The end of the paper tends to curl and make it tough to feed through the clamp?????? I use a small steel ruler behind the paper to aid in feeding it down through the clamp. Hope that helps. Quote
krtwood Posted June 9, 2013 Report Posted June 9, 2013 It's a PITA to get it tight. The clip should have more travel to help pull it snug. If it isn't really tight you'll have problems with either the last inch wearing out prematurely and burning, or it will slip and overlap itself somewhere in the middle and you'll get burning there. Quote
davestanton Posted June 10, 2013 Report Posted June 10, 2013 Are you using the tool supplied with the machine to open the clip? It works very well. Quote
PaulMarcel Posted June 10, 2013 Report Posted June 10, 2013 Are you using the tool supplied with the machine to open the clip? It works very well. +1 for the tool. TuffTool is what they call it if I remember correctly. You may not have it; on mine, it was optional, which makes as much sense as selling candles with optional wicks. Best $7 I spent on the sander. Here it is from an online site for $14; likely the new price for it. I got mine from Woodworkers' Source, which sells a lot of Jet equipment. http://www.ereplacementparts.com/tuftool-p-449095.html With it you can get the spring-loaded clip far enough back to pull the paper taut (until a new roll stretches...) That some people can do it without the Tuftool means some people have very small coordinated hands. Quote
CessnaPilotBarry Posted June 10, 2013 Report Posted June 10, 2013 I have sausage fingers, and the Tuff Tool, but I only used the tool one or two times... With practice, I found that I could hold the mechanism against the inside of the drum with one finger, open the clamp with a second, and use the other hand on the outside of the drum to slide the paper into place. Once the paper tail was in, while holding tension with the outside hand, I use one of the inside fingers to sweep the tail against the clip, then release. I'm sweeping the tension onto the tail as the clip closes and the arm tension spring pulls against the paper. Another thing that takes getting used to is estimating how much paper to put into the non-sprung end of the drum. Once you get comfortable there, the other end is a lot easier. If you're trying to put too wide a tail into the sprung-end clip, the width of the paper makes it harder to slide all the way home. On new paper, I'll sand a pass or two and retension, on previously used paper, it's usually not necessary to retension. This all happens on a Performax 22/44, which may or may not have more finger clearance than other versions of machines. In all seriousness, I've gotten to the 90 second mark on paper changes, without the tool... Quote
