Well, my used tool collection is begging to be added to and i am considering a delta 50-903 5hp. The used purchase would also include spiral 8" ducting and just about every accessory i will need to upgrade my whole shop plus add ons for later. The previous owner was a furniture maker who hired a company to come in and duct it out. I havent found any negative reviews or comments about the machine. I dont know anything about what the impeller saw. The guy tells me that it has sat unused for 6 years. My table saw sat unused for 3-4 years and it runs great now. Im thinking that i would like to start it up without the ducts connected because i dont know what is in those ducts. Is it too ballsy to show up and ask to dismantle the machine to check out the impeller?
He is asking 2k for the machine, about 60-80 ft of 8" spiral pipe(cant confirm thickness) plus 6-7 90's and 3-4 wyes with six inch reductions. So far, seems reasonable... Anything i should check into?
Thanks!
I'm always a little cautious about used equipment from a production shop.  Having said that, I'd ask why it has sat unused for 6 years? Problem with it? No work? Mid Life crisis, bought a speedo, ended up in Florida?
Fire it up and look for vibrations - impeller unbalanced due to a bolt that got sucked up and took part a blade off at mach3.
It would have to run before I'd consider it. "Oh it's just not hooked up" wouldn't fly. You may want to try to get a feel of the level and type of production he did to think about wear and tear levels. Lots of hand tools vs 12 Adirondack chairs per day for 10 years.
There are guys here that know electricity and tell you about clipping an amprobe around the wire and look for excessive amperage draw which speaks to the amount of wear on the motor. Just a few thoughts.  May be a deal.
My first comment would be - do you really need a 5HP DC? Or is it an opportunity to get one? How much ducting are you goign to install?
My second comment would be to +1 Tim's comment (no, not the one about the speedo).  You need to have it run to gauge noise and vibration.  No telling what's been bounced off the impeller over the years.
The 50-903 is a cyclone you dont need to worry about what has hit the impeller. Things dont hit the impeller on a cyclone like they do with a bag type collector.
As Pumbaa said in Lion King..."I grovel in your presence"...yeah I hadn't thought of that. PB, is there a way (without dismantling everything) to check the play in bearings on the motor that runs everything?  Also, Is there a way to know how much wear is on the wall of the cyclone where everything enters the cyclone?  I don't own one, but I've read that there is often wear there.  I don't know if it's a concern.(?)
    As John suggested Spencer, you may not need such a large DC unit but my opinion is dust collection an area where if you're going to do some overkill, it's not a bad thing because of safety.  I still refer to the Youtube video on
.  It's basically a 2 part Laguna commercial but it is a heck of a shop and it has a heck of a dust collection system.
The body is not going to have wear unless it was used for sand. Yes reach inside the hole where the filer bags connect. You can check the motor for slop. Look at the motor paint for heat damage.
When we remodeled the shop, I planned to have space for 2 people working at once. I believe that the 5HP will be able to handle sufficient collection at two machines simultaneously. the shop is only about 500 sq ft. so i only plan on using about 50 - 60 ft of pipe. I have always found thyme's tour to be useful and fascinating. I am definitely planning to turn it on and make sure it runs smoothly. I'm also going to disconnect the pipes that are currently connected because i don't know what kind of crap has collected in there over time. the guy who is selling it, went from furniture to general contracting which IMO seems kind of backwards but everyone is different.
going to check it out in person next week and bring an amprobe
An amp probe will not do you much if any good, amperage draw is going to change with load. You dont have known values. 3-5hp is about right for a one or two man shop IF your good about closing blast gates.
==> You can check the motor for slop.
+1
==> The 50-903 is a cyclone you dont need to worry about what has hit the impeller.
well...  As Don says, things can't 'hit' the impeller -- not like a bag system -- but things can get tangled-up and leave their marks -- depends on what's sucked-up and how it bounces after hitting the back of the cyclone.  Over the past decade or so with my current cyclone, I've managed a few 'special' moments...  The best was a piece of twine that had a bolt-eye on the end that was supposed to being hanging a piece of drying kit to the ceiling....  It took me an hour to unwind that from the impeller...
Over time, everyone sucks something into the system that they shouldn't -- junk will normally just hit the back of the cyclone and fall into the bin... Last year, I had to take my unit apart last year for an upgrade and could see every one of those 'oooooops' moments written in the metal (generally scratches in the impeller blades -- but the odds of chipping the bade would be rare -- as Don says).  So if you see actual chips in the impeller blades (typically at the edges) -- that would indicate sustained abuse...
BTW: 99% of all 'ooooops' moments with my system involved floor sweeps.  At one point I had five in my shop and was constantly sucking junk into the system.  Now I have just two -- 1 near the bench for plane shavings and one near the assembly table (where I do my routing)....  If they don't have floor sweeps in their system, then the odds of abuse go way down...
==> 3-5hp is about right for a one or two man shop IF your good about closing blast gates.
+1
==> 2k for the machine, about 60-80 ft of 8" spiral pipe(cant confirm thickness) plus 6-7 90's and 3-4 wyes with six inch reductions. So far, seems reasonable...
If the spiral pipe is in good shape, then that alone would be worth a grand.  Get rid of the 90s -- unless they are wide radius 90s...
==> My first comment would be - do you really need a 5HP DC?
depends on whose 5HP? -- one guy's 3HP is another 5HP.  In the last decade or so, HP has become more of a marketing spec and there has been definite 'HP creep'.
==> An amp probe will not do you much if any good, amperage draw is going to change with load.
+1
==> I am definitely planning to turn it on and make sure it runs smoothly.
you can only turn it on if it's connected to a system....  if there is no load or bin, the motor would overload in under a minute...
