schdecoy Posted March 2, 2014 Report Posted March 2, 2014 I have both the powermatic with jet chisels and the domino and would not give up either one. Quote
Pwalter5110 Posted March 3, 2014 Report Posted March 3, 2014 I don't know if it is still going on, but powermatic is having a sale on Amazon and I believe the hcm is under 1k Quote
Byrdie Posted March 14, 2014 Report Posted March 14, 2014 I have the Delta add on for the drill press and use it quite a bit. I'd use it more if it were easier to set up, but it was in the budget when I found it and I have a hard time throwing out or replacing a tool that basically works. When the budget expands a bit I'm pretty sure I'll go for something a bit more solid. I find myself using the 3/8" chisel the most. 3/4" lumber, tenon centered on the stock, you do the math. Quote
