A question about lumber racks and block walls
Now that the kids have all moved away I am finally able to start on improvements in the shop. The second of which is the basis for my question.
My garage (aka the shop) is concrete block and I am trying to determine the best method for attaching a lumber rack. My lumber has been stacked against the walls until now....
Thanks in advance,
Chris
What about not bolting it to the concrete blocks, but rather go floor to joist with the vertical support?  Secure it to a joist above, and secure it to a cleat which is screwed to the concrete floor...
Thought about that... however the ceiling was done with a very nice double knockdown finish on the dry wall. I would like to keep it in good shape from a resale perspective.
If you have the ceiling height, or if the majority of your lumber is 8-9’ long or less, consider storing the lumber vertically. I did this in my garage. I built a small platform out of plywood and 2x4’s to sit on the ground, and attached some pipes to a 2x4 installed into the wall, which the boards lean against.
The best part of this storage method, as opposed to a horizontal lumber rack, is that I can quickly flip through the boards to figure out which one I want to use, and it’s easy to get an individual board in and out. It also takes up less floor space, at the expense of more wall space. There’s very little force applied to the wall with this configuration.
More pictures, etc. are located here: http://giantcypress.net/post/5388073797/the-worst-part-about-building-a-new-lumber-rack-is
Have you noticed any problems with boards warping or anything since doing this?
What about just a free standing rack made out of 2x4's.  Like a simple garage shelving unit.
I have a reinforced block wall (Florida) and simply have heavy duty shelving standards bolted to the wall. I have a bolt every place there was a spot to put a bolt, rather than just at the top and bottom, in order to spread the load. However, I don't stock a ton of lumber, and generally only have about 100 lbs of wood on there at any time.
I REALLY like that vertical lumber rack idea. and was also wondering about warping.
Another idea might be warehouse shelving and stacking the wood right on shelves. They're built to take the load, are portable and around here at least, they're cheap on Craigslist all day long.
I built my rack 2-1/2 years ago. During that time I’ve had no problems with warping at all. For that matter, there’s been no problem with stability, either, even though the plywood platform simply sits on the floor. It’s not anchored in place at all.
I think that warp isn’t an issue because of the pipes and the 1x4 stops I put into the plywood base. You can see that at the link above, but here’s what it looks like.
Most of the weight of the board is borne by the platform and the floor. Each section leans up against the pipes, but it’s only 16” of distance between the pipes, so the amount of weight that each pipe has to bear is minimal. Because of that, any lateral force that would cause the board to warp is also minimized.
My feeling that if a board stored this way winds up warping, it was going to move enough that it would cause a lot of havoc with your project anyway. I also wouldn’t store green lumber this way, but the vast majority of the lumber I get is already dried. It would be different if I was milling my own logs.
And I’ll repeat this, just in case anyone is still considering a horizontal lumber rack, because this is really the best part of my lumber rack: because of the vertical storage, it is ridiculously easy to access any board that I need. Boards stored horizontally have a tendency to arrange themselves so that the board you need is always at the bottom of the pile.  ^_^
I store my lumber vertically and have not had any issues with it bowing,
I am almost done build a new cart for my garage shop? Hopefully I will be able to get pictures posted tonight or tomorrow.
Vertical is fine.  If David Marks does it and I do it, it must be right.
Yup, that's a safe bet!  Wait, you're friends with David Marks?   :P
All,
...plus you don't have to sticker right?
  • 3 weeks later...
Nice storage Wil! I have the horizontal also on cmu. I used a threaded insert specific to cmu or poured walls that can be used with 1/4" bolts. I bolted kv shelf standards and used their heavier duty standards. Works fine and has been up for years with a full stack of syp 2x10's. It can be done, but it is primarily for long term storage as Wil mentions, its a b@%% to select a board!
I really like the vertical storage for lumber, if I had taller ceilings and did not have to multi-purpose the building, I could very much see doing that.
I finally got the report done on my new cart.
So far I am liking it, I still have to build a "corner post" for it, but I want to get one or 2 things done first.
