guitar10000 Posted October 15, 2010 Report Share Posted October 15, 2010 Hello , I recently bought a Woodriver Drawer Lock Bit 1"D 1/2"CL but it did not come with any instructions. The only help online I have found is for a 2"D bit. or a 45degree lock bit. Does anyone know where I can get setup info for this bit? Or should I just start making lots and lots of test cuts? Thanks Quote Link to comment Share on other sites More sharing options...
Onboard Posted October 15, 2010 Report Share Posted October 15, 2010 Hello , I recently bought a Woodriver Drawer Lock Bit 1"D 1/2"CL but it did not come with any instructions. The only help online I have found is for a 2"D bit. or a 45degree lock bit. Does anyone know where I can get setup info for this bit? Or should I just start making lots and lots of test cuts? Thanks Guitar10K, if this is your bit, then Woodcraft sells a similar bit made by Whiteside Machine Co., and Whiteside has a general set of instructions here for all bit sizes of this type. By the way, the instructions are NOT for the 45 deg bit. They have a separate set of instructions for that bit. Don’t know if these instructions will help you but you might take a look. Quote Link to comment Share on other sites More sharing options...
bullson Posted October 16, 2010 Report Share Posted October 16, 2010 the voice is a bit boring but it give you a good understanding of what to do. however nothing beats a good bit of fiddling around with scraps hope this help Quote Link to comment Share on other sites More sharing options...
Bobby Slack Posted October 18, 2010 Report Share Posted October 18, 2010 Great video. I was trying to use one of my CMT bits for a joint like that one, when after reading the instructions for 10 ... yes ... ten ... times, I realized my piece was not thick enough. So I will make for the fun of it a drawer lock joint with a 3/16" bit and do this manually. I will use 3/4" for my drawer lock construction bit. I will also do a rabbet dovetail drawer as Marc did for the guild. I like how it looks. Quote Link to comment Share on other sites More sharing options...
