DaveT Posted March 26, 2014 Report Posted March 26, 2014 Hi everyone, I need a bit of advice on buying my first Bench Drill. I am currently looking at making a rustic garden bench from pine logs (up to 4" diameter) and want to use mortice and tenon for the joints. That is a lot of mortices to cut by hand and there is no way I can use a battery drill accurately enough to get decent results. Therefore my only options seem to be: Train some woodworm to eat the holes for me or buy a drill press to do it and then finish off by hand. As money is as tight as space is I've been looking at these: http://www.amazon.co.uk/Silverline-262212-Drill-Press-200mm/dp/B002QRYEBQ http://www.machinemart.co.uk/shop/product/details/clarke-cdp5eb-5-speed-bench-mounted-pillar-dri and also these bits: http://www.screwfix.com/p/wood-drill-bit-set-35-pc/75037# Any help/advice you can offer on suitability/alternatives will be most greatly appreciated. Dave Quote
TerryMcK Posted March 26, 2014 Report Posted March 26, 2014 Hi Dave welcome to the forum. I wouldn't really recommend anything made by Silverline. I would also be inclined to avoid the slightly better (but not by much) Clarke machinery from Machine Mart too. If you want to buy something new without wasting money you are going to have to increase your budget. The Jet JDP-8 or Axminster AH1302DP would be a good choice as they are both around the same price and great after sales service. Have a look at axminster.co.uk for details. The other one you could consider is the Record Power DP16B here which is currently on promotion (also here). Record Power have superb after sales service and their machinery has a 5 year warranty. Alternatively have a look at eBay, Craiglist or Preloved for second hand stuff that may still be within your budget. You can get some great bargains on preloved.co.uk but of course there may be problems with bearings or motor wear on older stuff. As a starter set those you quoted from Screwfix might be ok but I've found with sets like that the Forstner bits are not very well made and clog easily. Buy cheap buy twice. Quote
EdgewaterWW Posted March 26, 2014 Report Posted March 26, 2014 "Train some woodworm to eat the holes" ---- that is funny! Also I understand "money is as tight" I work on a budget also. But I think the drills that you are looking at are too small, the first drill not much info about it, the 2nd drill "Chuck to table 167mm" 6.5" you said you will be using 4" logs (4x4 legs?) with a 4x4 on the table you would only have room 2.5" long drill bit. I would buy more like this one http://www.machinemart.co.uk/shop/product/details/cdp151b-drill-press Chuck to table 290mm 11.5" and not buy a full drill bit set, for now get one bit that you need for this project. Other idea to save time from drilling then chisel out the mortise. Get a http://www.machinemart.co.uk/shop/product/details/cma1b-mortising-attachment with a mortice bit http://www.machinemart.co.uk/shop/range/guid/3E0851ED-B9A5-4565-843D-5089D4E0CE5C?da=1&TC=SRC-mortise Good Luck Quote
EdgewaterWW Posted March 26, 2014 Report Posted March 26, 2014 Here is a great video to watch, I like the router option 10 - Mortise and Tenon Options http://www.thewoodwhisperer.com/videos/tenons-anyone-pt1/ More info on using a router and jig http://www.thewoodwhisperer.com/viewer-projects/bryans-router-mortising-jig/ Quote
knotscott Posted March 26, 2014 Report Posted March 26, 2014 Most of the lower end DP's are pretty similar....get the most capacity and largest motor you can afford. Quote
DaveT Posted March 27, 2014 Author Report Posted March 27, 2014 Thanks for the replies and advice guys. I've since ruled out the Silverline one as the collar on it is only 40mm and I do want to get a morticing attachment at some point. You raise a very valid point about the clearance Doug and one that I have to admit I hadn't thought of The router option is I must admit also one that I hadn't considered. More investigation needed I think. I'll certainly be keeping a close eye on ebay and pre-loved (I did try for one on pre-loved but missed it by minutes). In the meantime I'm going to start looking for some trainable woodworm Dave Quote
