Delta 1440 46-715 Lathe
1 minute ago, temptmewithawoodtime said:
Thanks for the quick reply!  So it looks like the handwheel attaches directly to the read half of the spindle pulley?  There aren't any parts or connectors in between?
To me it appears the hand wheel slides over a shaft with a bolt to hold it to the shaft.
  • Replies 58
  • Views 65.3k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • Jeff Peters
    Jeff Peters
    I have the Delta 1440 lathe and the reeves pulley on the headstock is bad, the slot that it slides on the keyway wore out. I replaced it with a 1 horse 3 phase motor and a VFD, I should have done that
  • Brian Jenkins
    Brian Jenkins
    Mine did this last night
  • Fastenal.com lists many styles of pulleys from 2 different manufacturers - Bearings Limited and TB Woods.  On the site, they do not list a variable pulley.  Basically, since they have a relationship w
Posted Images
The bolt is going into the side of the handwheel or are there screws going through the length of it?
  • 1 year later...
I picked up a delta 1440 type 2 lathe with a bad bearing in the headstock.  Trying to remove the spindle, I removed the hand wheel, and the back reeves pully.  The inner reeves pilly looks like it is pressed into another bearing in the speed change yoke.  I have removed most of the snap rings, except the largest one facing the front of the spindle in the yoke.  Has anyone removed the yoke?  do you have to remove the speed control lever to remov e the yoke ?  can the reeves pulley in the yoke be removed without removing the yoke?
And help on disassembling and removing the spindle will be appreciated.
  • 2 months later...
We are looking for a clutch for a Delta wood lathe, Iron Bed 1440, 46-715.  Do you know where we could purchase one?  We are in Canada but are near the U.S. border and can pick up items posted there.  Yvonne
  • 1 month later...
I have the Delta 1440 lathe and the reeves pulley on the headstock is bad, the slot that it slides on the keyway wore out. I replaced it with a 1 horse 3 phase motor and a VFD, I should have done that years ago. I can slow it down to about 50 rpm and it has reverse. I bought a used motor for $40 and the VFD was $70 new off eBay.
  • 5 months later...
So I recently bought a delta 46-715 Lathe and the revees pulleys are missing / broken parts of them does anyone have any suggestions on what to use saying I currently converted it to a step pully
  • 2 years later...
Could someone give me the specs for the 4 step pulley in particular the diameter of steps. How is the slack taken up when using the small diameter step? The Reeves drive pulley on motor self-destructed on my 1440 lathe.
Thank you
Steve B
  • 6 months later...
Any luck Walt?
I need to pull the spindle and replace the bearings.  I'm hoping to get some advice before I just get a bigger hammer.
