Better hand-held belt sanders
I have two hand-held belt sanders. Their flat belt sections are about 6" and 8". My problem with them is that I invariably grind off material that I want untouched. I don't quite understand why or how this keeps happening, but it does.You would think that by simply keeping the flat portion parallel to the surface being ground, there would be no problem, but I am going to have to use wood putty to replace those portions of the structures that I hadn't wanted to grind away.
Anyway, it seems to me that one way a sander could be made safer would be to have the belt portion mounted so that it could be raised or lowered between two parallel rails on either side of it. In other words, the sander would rest on the rails until the belt was lowered so that it projected below them to any desired depth.
I've looked for such sanders but couldn't find anything. Do they exist?
Yes, that's a sanding frame.  I don't have one, but the Festool belt sanders have that frame as do the Elu belt sanders they are based on.
Doing a quick google, I found an article from Fine Homebuilding specifically on sanding frames so they name off other brands of frames or third-party frames
http://www.finehomebuilding.com/how-to/use-a-belt-sander-frame.aspx
This is really a special place. Every question I've asked has been answered quickly and comprehensively. I couldn't ask for more.  Anyway, thanks for the advice and the link. I was actually a little reluctant to post my question because I didn't want to be laughed at. I was dreading something like, "You must have ten thumbs," but now I see that other people sometimes have the same problem. It's nice to be redeemed, to learn that you're not a total klutz.
Niku, Using a common belt sander without digging in takes practice, there is a knack to it and not many folks can say they didn't dig in at first. Like a lot of other tools, the more you use it, the more accustomed you become to it's inherent nature. I consider myself "okay" with a hand held belt sander, but my buddy who has been using one for years is "excellent" with it. You should practice on some scraps until you get a better feel for it. One thing that you probably already know is to never stop motion with a belt sander. I find letting the tool do the work, much like a drill bit doing the cutting, rather than forcing it really helps. Most everything else is feel, and practice. But you're not crazy, it's a tough tool to get used to!
One other thing. Belt sanders are different sizes for a reason. If you try to take a light pass on a small soft wood board with a 4x24 belt sander with 80 grit paper, you are setting yourself up for failure.
This is a place of joyful learning!  Those of us that had ten thumbs when we came here now have replaced several of those thumbs, with fingers and a little more knowledge!
Niku, I'm w/ you. I've asked some pretty elementary questions here in the past, halfway expecting someone to tell me to go to the internet for the answers, but that's never happened. It seems that someone has also had that same question/problem and answered it from their experiences. Every once in a while a complete a-hole will pop up but they are quickly snubbed by Marc or Kiki or countless others that don't tolerate that kind of crap :D . Welcome to the Forum my friend and keep those "dumb" questions coming; I know I do :D
