Finish for a Work Bench
I was watching a video of Christopher Swartz giving a lecture about work benches and some options for sealing. To be honest the sound on the video wasn't the best so I'm left a little confused.
I "think" he said something along the lines of mixing linseed oil with other finishes.
It's going to be a bench used for working, not a piece of furniture. I would like to have a basic finish to give some resistance against glue and other finishes.
Dumb question, but do stains provide any protection? Besides the the obvious weather elements.
thx
Some finish is better than none, a couple of coats of boiled linseed oil seems to be the norm. The bench just needs a little protection, but if you use a film finish you risk chasing after your work as it skates around the bench. So I'd avoid wax too. Put an old bed sheet over the bench when you glue up or finish your work.
John
Yes I agree with John. I just use anything I've got in stock that isn't a film finish. I think last time I did it I just used some outside decking oil/varnish blend. When glue falls onto it a card scraper will remove the dried spots of glue or just wipe it off while it is still wet.
Watco or other Danish Oil works well, touches up easily, and isn't slick.  For large glue ups or staining I use a roll of kraft paper from the big box store anyway, but the oil does help keep things from sticking.
I used 4 coats of water based poly, but only because I had it lying around. It's been over a year and it's holding up really well.
That's an interesting idea.  In general, how does the sheet react when glue drips down onto it?  Will a typical amount of squeeze-out drips end up seeping through and gluing the sheet to the table?  I suppose even if it did, a simple tug on the sheet would dislodge it and pull the glue up from the bench, right?
It depends on how you glue up. I'm not the hamburger sauce type, with glue dripping all over. I like just a little squeeze out so I usually only get a stray drop or two getting away. Alternatively a thickish sheet of plastic or even a sheet of hardboard will protect - they just take up more storage space when not in use.
John
A basic stain will not provide you the protection you're looking for from glue drips.  Glue will still stick.  But many of the solutions mentioned above will give protection from glue; like a film type of covering like a poly or an oil - like boiled linseed oil.  It also kind of depends on the work you will be doing.  Hand tool guys like to keep the bench a little "grippy" to keep from having to chase your work so much as John said.  If I remember correctly when I read Schwartz's book "Workbenches: from Design and Theory to Construction and Use", I THINK Schwarz offered options for sealing benches but he preferred to use no finish on his bench and he's a big hand tool guy.  I have no finish on mine (I'm not a huge hand tool guy).  I'm like you, furniture is for inside the house  and work benches are for work.  I hope to pass a bench to my sons that is well weathered and full of battle scars...and stories.
I just keep a roll of paper handy and like John, I try not to 'sauce the work'...only the ribs....and the chicken..and the roasts.....oh mercy...I've digressed into something really nice but not applicable here.
I'm not so sure I'd wanna deal with a crusty old sheet, but you can buy big rolls of craft paper for stupid cheap on Amazon and other sites...
http://www.amazon.com/Pacon-5850-Kraft-Wrapping-Natural/dp/B000NDKVJY
That's what I use.  Rip off a few feet, tape down the corners, booger up, dispose.  I use my TS outfeed/assembly table instead of my bench unless I'm doing a weird glue-up that requires clamping options that only the bench can offer.  Very often the bench is too long and skinny for convenient glue-ups...I find the larger surface area the outfeed table offers to be far more accommodating to spreading out your clamps and work pieces, glue, roller, brush, clean-up stuff, etc.  The bench gets crowded pretty fast and a lot of projects are too large for the 24" depth of the bench.
Regrettably I used BLO on my bench...it provides exactly the amount of protection that I wanted/needed...but my maple bench did turn yellow.  At the time I thought I wouldn't care, but if I'm honest it does bother me a quite a bit.
If I could do it over again, I'd use a non-yellowing oil...I still wouldn't put a film finish on it...gets too beat up for that to make any sense.
How dare you slight the Schwarz!  Just funnin'  :D
I am in the BLO camp (which is no longer boiled, ironically).  Also appreciate TerryMcK's input:  anything that isn't film.
On my current bench, I last used a toothing plane and BLO and I am satisfied.
miw
I've recommended it for dust and chip catching for lathe work, and I think a cheap shower curtain from a dollar-type store would work for glue time as well.
I went the wax route for my lathe bench (MDF top), and I agree with John: Don't.  It held up for about two weeks.  I'm actually glad the raccoons got into the shop: I need to replace the bench top now, and can look into other options.  I do agree with others that furniture gets finish, and benches get beat... but I have other requirements of it than just take a pounding.  For now, anyway.
  • 26,009 Total Members
  • Joseph b Newest Member ·
