I have a Bosch 10j (European jobsite table saw)  at the workplace and even though the blade (which came with the saw) has a 30mm opening, the arbor is 16mm or 5/8''. There is a bushing for the 30mm blade to sit in the arbor.
Some pictures of the saw:
The 16mm to 30mm bushing:
post-17356-0-55986900-1426599360_thumb.j
Bushing and 30mm blade:
post-17356-0-22365000-1426599367_thumb.j
The arbor:
post-17356-0-93049900-1426599372_thumb.j
A skill saw blade installed without any bushings:
post-17356-0-43982200-1426599379_thumb.j
Questions:
1) Do you think a dado set like Freud's will work  in this saw? Looking at the pictures I took, I see there's a gap at the start of the thread, that could be a serious obstacle, but I don't know.
2) If 1) is affirmative: Do I need to buy new bushings? If you know about the right ones, a picture or URL will be appreciated.
My Ridgid contractor saw had an arbor with a gap that a dado blade would fall into and therefore cut deeper than the rest of the stack.  They had a replacement arbor that fixed the issue which I eventually installed but what I did was just fill that area with epoxy.  You want an epoxy that's pretty viscous so it doesn't all just run to the bottom.  A little sanding after it sets up until you can get the blades over it and you're good to go.
Thank you. That's an excellent solution to my problem.
And what about the inner and outer bushings? Did you need new ones?
  • Who's Online   1 Member, 0 Anonymous, 42 Guests (See full list)
    26,008
    Bob44
    Bob44
