Randy Thurman-Keup Posted August 2, 2015 Report Posted August 2, 2015 I happened upon this pruning saw (at least I think that's what it is) in a small collection of tools I grabbed at an auction for $2. The one side seems to be relatively normal teeth, but the other side has the larger teeth reminiscent of lumber saws, with each tooth in a pair set opposite the other. I'm confused as to how the larger teeth are supposed to cut, and hence how to sharpen them. Anyone know how these teeth are supposed to cut? I think I know how traditional large crosscut saw teeth work, with the slicing teeth and the rakers, but the rake angles on the teeth on this saw have me a little confused. Thanks for any advice.Randy Quote
Tom King Posted August 2, 2015 Report Posted August 2, 2015 (edited) One side is just like a crosscut handsaw-probably for dead, dry limbs. The other side looks like it still has plenty of set, so I'd just follow what's there to sharpen it. I have one similar that only has the teeth that cut both ways on it, but it's shaped more like a regular handsaw. I have sharpened it a couple of times, but it's been so long that I have no idea what size file I used-probably the largest triangular file I have, or maybe even a 6" Mill file. I think the only thing I've ever used it for is cutting down Christmas trees. Angles are not so critical as for a saw to cut dry wood. This one is for green wood, and sharp will cut.I was just looking at this today, but didn't order it. scroll down and look at the middle page in the second row of page pictures. It's not the same, but I thought it was interesting. The teeth on your saw cut coming and going.http://www.ebay.com/itm/1871-Art-of-Saw-Filing-Sharpening-Book-Workshop-How-To-Guide-on-DVD-/171478304076?hash=item27ece7454c Edited August 2, 2015 by Tom King Quote
Randy Thurman-Keup Posted August 3, 2015 Author Report Posted August 3, 2015 Thanks Tom. I took a closer look at the teeth under a magnifying glass and noticed that the inside edges of the teeth in each pair are filed with a fleam, with each tooth designed to sever the fibers in the opposite direction. As you said it cuts coming and going. But I think the back side of the teeth, which border the large gullets, are designed to act as the rakers on the return stroke to clean out the wood from the slicing half of the stroke. Anyway, I thought it was interesting. Quote
