Help!! Miter Saw Problems.
So I just picked up a used DeWalt DW717 (10" sliding miter saw) and I'm in the process of cleaning & tuning it up. It was previously owned by a trim carpenter who was amazed at how accurate it is.  But accurate is a relative term of course.  I like my machines to perform darn near perfect and I'm having trouble getting this one adjusted properly.
My problem is:
When I use it like a regular "chop saw" (with the slide stop engaged) I'm getting perfect 90 degree bevels but the miter is off by a few degrees.
And when I use it as a slider (with the slide stop disengaged) I get perfect 90 degree miters, but the bevel is off a few degrees.
Does anyone know how I can adjust this so I can get 90 degree cuts everywhere.
If I adjust it so that it cuts perfectly as a chop saw, then it's off on both bevel & miters as a slider. And if I adjust it so the slider cuts perfectly, then I can't use it as a chop saw.
What am I doing wrong?
Any advice is helpful thank you!
Here's a couple pics in case anyone doesn't know the specifics of what I'm referring to.
My saw is very similar to yours, both Dewalts. Check the fence to table squareness, check the fence to fence alignment. If you shift the adjustable top part of the fences check those again, it's easy,for them to be off slightly.
Check the stock you are cutting for straightness and square. Check that you have it tight to the fence when cutting. How you hold the handle and which way you apply pressure can flex the little bit of play in the mechanism . In other words you have to pull it dead straight or push down straight and smooth. Any deviation of your pressure will slightly affect the cut. I'm only talking about very small amounts, nothing a trim carpenter would worry about. But when making furniture grade cuts it matters.
I use my sliding table & tablesaw for really accurate cuts. A sled works too .
Dan, I have the same exact saw but only use it for batching out parts. It's new and cuts fairly well, but it will never compare to a good miter sled for the table saw no matter how well you dial it in. A lot of guys make their own sleds but I went ahead and bought an incra miter express. It's easy to dial in perfectly and the crosscut and miters are a thing of beauty. If you have a quality table saw, you might consider getting or making a sled and dedicating the SCMS for breaking down material.
Thanks Steve, I appreciate the insights.
So far I've been using the front detent screws to adjust the miters, and the bevel adjustments at the back of the saw for the bevel, I have not touched the fences yet because they are square to the table.  The stock I'm using to test is 3/4 oak that is flat and square.
What I'm really struggling with is understanding how the inaccuracy consistently shifts from the bevel to the miter when switching from the chopping action to the sliding action.  I can't wrap my brain on what is happening that the error flip flops from bevel to miter.
I hadn't thought of how I might be affecting the cut when I'm cutting, so I'll pay very close attention to my arm movements to make sure that I'm not tweaking the saw at all, but due to the consistent repeatable error, I have a feeling that this problem lies somewhere in my setup of the machine.
Thanks Janello, unfortunately I don't have a tablesaw at the moment so I can't rely on that. But I agree, sleds are the way to go.  When I had a tablesaw my sled was extremely reliable.
I have this exact saw and have not noticed your error though i just use mine with out the slide lock engaged at all times and squared it up in that configuration. I figured the slide lock was for transportation.
Is it possible that your are experiencing the error everywhere and you just aren't noticing it on the smaller material?
I'm using the same piece of stock when testing... I think I might have to do what you did and just setup it up for the sliding motion and forget about using it in the chopping motion. No big deal I guess, but it's disappointing though, I generally like to dial in all my machines to near perfect accuracy and then not have to think about them for a long while.
Sent from my iPod touch using Tapatalk
  • 26,009 Total Members
  • Joseph b Newest Member ·
