Barbie doll shelf for my daughter with my Badog CNC
I’ve been working with badog software for about a year now I was quite convinced that I can make this drawing in less than an hour but in reality it took to many twists and turns and I started to get really creative with my drawings. So it took a little bit longer than expected. you can see below the outline of the pieces and went at as usual on using 3 mm thick plywood with a 1.1 mm diameter tool with 2 teeth.
once all the pieces were cutout of the wood I started to assemble them and had realized that one of the pieces and drawn upside down and if I put it together it would be backwards on the finished model so it was back to the drawing board and I made another piece and erased the original false piece. The entire project took about 15 to 20 minutes to cut if you don’t count the time I lost redoing the DXF files in the bundled software I had received with my machine.
here’s an image of the semifinished Barbie doll bookshelf partially assembled before I painted pink.  I had to disassemble the entire model in order to get the pieces perfectly covered by the pink
well here’s the finished project all painted of the Barbie bookshelf
I know there used to be a good market for this stuff.  Not sure the market is still there?
Interesting the way it fits together.
Great job on the doll furniture! I'm sure she'll love it. I think I'd clamp or double face tape a piece of 1/4" MDF under the plywood so that you can cut through without risking damage to the table.
Does your software have inlay capabilities with automatic offsets?
Here are some computer workstations I made using the same slip fit method of construction. Quick, easy and cheap!
with now days kids play with tablets and smarphones but I'm sure there is good market for this stuff.
  • 26,012 Total Members
  • JAR Newest Member ·
