model guys so I need some help on making a decision I have the opportunity to purchase a older Craftsman 12"belt drive band saw - sander off Craigslist for 50 dollars I currently have a 9" skil bench top band saw that I bought brand new what is your opinion should I purchase the 12" craftsman if it's in good shape and just put a new good blade on it? My thinking is 12" floor model has to be better than a 9" bench top if it runs and everything works good right ?? Just seeking advice on what you guys would do in my spot I don't have enough money to buy a $ 500+ BANDSAW right now figured that would be a good upgrade for the time being?? Thanks guys for your help!
I had something similar in the 1980's and it is ok for a small saw. I just did some searching and reviews of used ones on other sites make it sound like it's worth $50 if it runs well. Depending on age some parts might be hard to find.
Thanks I did look online only reviews I seen was on lumberjocks from 2011 but they all paid 85-100 for there's and said it was a good deal for you think given it works good it would be a improvement on my little skil bandsaw?
It's an improvement and its affordable. As long as you aren't trying to resaw big  pieces it's ok. Sharp blade and don't feed too fast. You can probably sell it for what you paid for it when you can afford to step up to a 14" or bigger saw.
Awesome I think I will pull the trigger on it just need something to get me by while I save up for a14/12 but I'm sure I can sell my skil bandsaw for 50 or more do you know what size blade a 12" takes?
It'll probably be an upgrade but not by much.  If you're planning to build furniture you really need a 14" at a minimum.  Anything smaller is for making crafts and such, not really for serious woodworking.
It's only $50 so it's not much of a gamble...just go in with realistic expectations...it'll be underpowered and most likely difficult or impossible to tune to an acceptable level.  Fifty bucks worth of frustration, probably.
Whats the main difference between a 12 and a 14? That makes the 14" a necessity for furniture building?
There are a lot of clones of the inimitable 14" cast iron bandsaw; some good, some pretty poor.  I do agree that at this "step" you are potentially using a reliable workhorse.  I have an older 10" Delta that I picked up for $50 and it does earn its keep BUT, it is an accessory, not a primary saw.  The Rikon/Craftsman 10" steel frame saws get good marks.  I do not know that they would be a primary saw for furniture building however.  Just my 2 cents.
Thanks for the input guys I did purchase it last night. I'm not sure if the tire on the top wheel is bad or if it's a tracking issue but my blade stays right in the middle on the bottom wheel but creeps way towards the front of the wheel on the top I plan on replacing the tires with urethane tires regardless and reading the blade I didn't have much time last night to adjust the wheel to see if that helps the tracking also I plan to upgrade the belt idk what it's called but it's the belt that is linked together does anyone know if I can purchase new ball bearing guides from wood craft! I talked him down to 30 dollars last night sine I need to replace the tires so I believe I got a good deal
Try using it before you mess with the tires.  Wherever the blade rides on the top wheel if it rides somewhat centered on the bottom wheel leave it alone. I wouldn't invest in ball bearing guides for a saw like that. Clean it ,put on a sharp blade, adjust the guides (upper and lower ! ) and give it a try like that !
If the guides are quite worn maybe replace them with "cool blocks" but don't throw the old ones away.
  • Who's Online   1 Member, 0 Anonymous, 44 Guests (See full list)
