Pbmaster11 Posted January 5, 2011 Report Share Posted January 5, 2011 I would like to make some 1/8" or 1/4" edge banding for a project I am making. I do not have a band saw and was wondering if it is recommended to do these cuts on a table saw. Any tips, tricks, or no no's? Quote Link to comment Share on other sites More sharing options...
Beechwood Chip Posted January 5, 2011 Report Share Posted January 5, 2011 I had a similar question recently. You should look at this thread. I have pictures of my setup here. Quote Link to comment Share on other sites More sharing options...
Pete Bennett Posted January 5, 2011 Report Share Posted January 5, 2011 I would like to make some 1/8" or 1/4" edge banding for a project I am making. I do not have a band saw and was wondering if it is recommended to do these cuts on a table saw. Any tips, tricks, or no no's? I have a massive and very ancient table saw with a 20" TCT Blade and using a set up pretty similar to Beechwood's I've often gone down to 1/8" with no trouble at all. I do however, prefer to use my bandsaw now that I have one. Quote Link to comment Share on other sites More sharing options...
Beechwood Chip Posted January 5, 2011 Report Share Posted January 5, 2011 My 1.75 HP with a 10" 24 tooth rip blade had no problem with 2.5" poplar in a single pass. I didn't try any other woods, but I expect that I could handle any wood, making multiple passes if necessary. If you are edge banding I assume you'll be cutting 1" or less, which you should be able to do in a single pass in any wood on almost any saw. Someone (maybe Paul-Marcel?) recommended clamping the cut pieces face to face with the cut faces outside, to reduce curling. I saw a little curling on one of my 3/32" pieces, so this seems like a useful tip when cutting thin pieces. Quote Link to comment Share on other sites More sharing options...
