Need help with a repair!
I've seen just about any old wood used for bed slats. Something inexpensive and stable. Pine or poplar come to mind.
I don't think doubling up, or using wider slats, will hurt a thing.@Eric. just posted a bed that has wide slats, almost touching one another.
https://r.tapatalk.com/shareLink?url=https%3A%2F%2Fwww%2Ewoodtalkonline%2Ecom%2Findex%2Ephp%3F%2Ftopic%2F25792-D%26W-King-Bed---Walnut-%26-White-Oak&share_tid=25792&share_fid=38303&share_type=t
D&W King Bed - Walnut & White Oak
I'm definately in the camp that says to just use color matched caulk for a cosmetic fix. That post is not coming apart IMO.
Sent from my SM-N920P using Tapatalk
You can go for wider slats or just add in a few more. You can even put ply in there as a sheet...BUT...you must maintain ventilation to the underside of the mattress so if you use a sheet of ply you need to drill ventilation holes through it at regular intervals.
Regarding the crack in the post.
I would clamp it tight. Drill and countersink the holes and run in some screws. Get a plug cutter or wood dowel to fit the countersunk holes, find some wood filler to repair the crack, sand the crack and plugs smooth, stain, call it done.
-Ace-
