Need help with a repair!
I just received and assembled an adult sized bunk bed. It's a full XL on top, and a queen on the bottom. During assembling, I noticed a long crack in the wood (redwood). The crack is an inch deep, and about 10-11 inches long. It's on one of the posts on the bottom bunk. I googled how to fix this myself, and I notice wood glue works well for smaller cracks, where epoxy is good for the larger ones. Since I cannot take the bunk bed apart, which way is the best way to repair the crack? Which repair lasts the longest?
Also the crack is where you cannot see it, so I'm not worried about looks. I just want the best and strongest way to repair
How thick is the board and does the crack go all the way through ? You can slide a piece of paper or a playing card into the crack , mark it and see how deep it is. If the crack is open keep sticking playing cards in till it's full. A count of the cards will give us an idea how wide the crack is.
Not a woodworking fix, but a flat iron brace/bracket (I would choose black, if it's visible) will support the glue fix and will enhance the rustic look!  ;-)
This is the other side of the post (the outer side). So the crack must wrap around. It stops an inch deep on the inner side, so I don't think it goes all the way thru.
I kind of freaked out when I noticed it, and tried putting some super glue in the crack earlier today (I know nothing about wood). I hope I didn't screw anything up. I can fit 4 cards in there, and the super glue is still wet in there. I talked to a friend of mine who said the crack should be fine, but if I wanted to, I could put some dark caulking in there as its more flexible.  I wanted to double check on here because I don't want to potentially ruin this. I paid a lot of money on it and I love it. I appreciate all of your replies and help :)
It's already "rustic"!  I still go with the iron bracket, but it sure looks like that post would be easy to replace; whatever you do is going to be fixable.  Have at it.
Aside from replacing it, what would you suggest is best to fill the crack?
Like which would be the strongest adhesive?
Acrylic isn't bad; epoxy is probably better.  But hang out and wait for one of the experts to chime in.
[Edit: you will have to remove the post, probably tape it on ends and back side when gluing, leave in a horizontal position for the epoxy to cure.  You can color the epoxy with a dye - black would be a good choice.]
In response to your edit: is there any way possible to do this without removing the post? I saw a video where a guy used woodfill epoxy. Could I do that with it still in place?
That's the kind of check you get when the center of the tree is in the piece of wood.  I doubt any "fix" will be permanent.  It probably won't get bad enough that the piece comes apart, but no glue is going to hold it permanently.   If you did manage to do something to keep it from moving on that side, it will probably split on another side later.
Like Tom said, it may crack more in the future, so this suggestion is only cosmetic. You can try a 2-part epoxy putty, such as JB Weld, to fill that crack in place. This product is designed for metal repair, but I believe it will adhere to wood as well. JB Weld dries to a dark gray color, so it shouldn't be too obvious against that dark stain.
Or just leave it. I seriously doubt it will affect the strength of the bed in any meaningful way.
I have some PC Epoxy putty for metal here in the shop, but when I picked it up at the hardware store, I could swear they had some for wood.  I know they had a least a half dozen different types of 2 part putty, pretty sure there was one for wood.
EDIT:  found some!  https://www.amazon.com/PC-Products-45770-PC-Lumber-Moldable/dp/B008H4QV04/ref=sr_1_2?ie=UTF8&qid=1494597737&sr=8-2&keywords=pc+epoxy+putty
I'm with Tom & the rest, it is because 4x4 posts are cut from the center of the tree and they crack like that as they dry. Forget glues just use "Color Putty " Minwax makes 1 version. Pack the crack and smooth with your finger, it's only cosmetic . No need to do more and with all the knots no one will notice a crack once it is full of dark putty.
So to make sure I'm reading everyone right,  the crack pretty much a cosmetic issue, and nothing to really worry about?
I just want to make sure cus my son sleeps on this bunkbed. Thank you all for your advice! Purchasing some putty right now
One more question! I feel as if there may not be enough slats on the bottom bunk. I made a video, but it wont let me post it :(. There is a lot of give when i get on the matress tho (i dont feel it, but it shows). Should I add more slats? Or put plywood over them?
No box spring. Right now there are 10 1x4x62 inch slats under there. Should doubling up be okay? Or should I get bigger slats? is a certain wood recommended? Sorry for all the amateur questions lol I really appreciate it
I've seen just about any old wood used for bed slats. Something inexpensive and stable. Pine or poplar come to mind.
I don't think doubling up, or using wider slats, will hurt a thing.@Eric. just posted a bed that has wide slats, almost touching one another.
https://r.tapatalk.com/shareLink?url=https%3A%2F%2Fwww%2Ewoodtalkonline%2Ecom%2Findex%2Ephp%3F%2Ftopic%2F25792-D%26W-King-Bed---Walnut-%26-White-Oak&share_tid=25792&share_fid=38303&share_type=t
D&W King Bed - Walnut & White Oak
