Hostess Stand Project
Hello. I am putting together a hostess stand for a new Brewery/restaurant. I initially looked into a large unfinished poplar piece and they were asking close to a thousand for it and I did not want to invest that into something I would be redoing. I shopped around and came upon an old bank teller solid heavy piece for $60 dollar and bought it. It was a mess, but I was drawn to it. It had a lot of what looked like very flaky particle board inside the unit, but a nice solid powder coated MDF top. I am only taking a guess. I spent hours scrubbing it down. I used Stix and then Kilz because I ran out of the Stix and did not want to spend another $50 for a quart. I do not have a sprayer yet, but was able to get every tedious corner covered. It is very smooth. My question is about the counter top epoxy coating I will be applying. A thin beveled glass will be placed on the area the hostess workers will work on. The product is Rusteolum counter top paint in Cobblestone. I was going to cover all spaces with it. I have reconsidered this once I was in the middle of the tedious process of painting deep inside the unit. Would it be best to only cover the flat horizontal areas with the 1 part epoxy paint and paint the vertical areas with a chalk paint with a top coat varnish? I have not worked with the epoxy 1 part paint and do not want to get in a sticky mess with tight space and vertical areas (drips and many corners). The carpenter will add the whitewash pieces I refurbished from old wood on sides and back. He will add my wood bar slab on the upper ledge for the guest to come up and lean on. The workers will have the space below. There is also a drawer I redid and need to add updated handles or refurbish the old ones. I have not decided yet. Has anyone worked with this counter top epoxy paint? The unit pics are blurry because I was really tired at 10 when I finished and took a few snaps with phone which does not take the best pics.
Put the glass on the thin clear round disks that any glass company should have. If directly on the epoxy it may eventually stick or water might get under it and be a problem. If up on the disks it's easier to lift if you need to clean under the glass.
I haven't used that epoxy.
