collinb Posted November 3, 2017 Report Posted November 3, 2017 Am wondering if any here use manual-feeding drum sander solutions. I would guess those would all be home-brew units. How well do they work for you? Quote
Marmotjr Posted November 4, 2017 Report Posted November 4, 2017 Well, I do have to plan what I have "down range" from the sander, as it will launch the piece I'm working on if I let go. I routinely take the tops off my fingernails with it, but it also does wonders for getting glue off the skin. Because I'm leaning over the stupid thing, I have to sometimes wear a mask even with the DC running. Since I turned the drum myself, it's about 1/32 off from one end to another. So my last pass through, I run the piece twice to get it perfectly even. All that aside, It works great for me. A single screw in the back underneath adjusts the height, and it's very reliable and repeatable. I just have to occupy my lathe while I use it.... Quote
Dave H Posted November 4, 2017 Report Posted November 4, 2017 I made a lathe powered thickness sander modeled after a thickness sander that was on the woodgears web site. That sander used an electric motor, I used my lathe as a power I used this set up for several years It worked well for a manual feed unit It gave very consistent results, I needed to do some table tops so I bought a jet 16-32 now the lathe powered thickness sander was dismantled here's a video of it in use a day after it was finished I started using the next piece to advance the first piece through the sanding cycle. Quote
Marmotjr Posted November 4, 2017 Report Posted November 4, 2017 Also, I believe Stumpy Nubs has a shop built two stage DS on his site, possibly for sale if not free. It's an impressive machine. Quote
