The one thing I don't really like about the CV1800 is that you have to seal up the filter stack with silicone.  It's a real hassle for me because I have it tucked into a small odd shaped closet and the filter stack is right next to a wall which makes it impossible to get a caulking gun all the way around.  So I wanted to come up with a replacement for the silicone.  Wynn Environmental, who make the filters, have a gasket, RG-13, but it's too thick to fit three of them with my limited ceiling height.  They are also pretty floppy and there's nothing to hold them in place so you would need plenty of room to be able to work with them.  Weatherstripping would probably work but again with my limited ceiling height I thought I would end up damaging it trying to get everything into place.  I found a thin rubber gasket at Mcmaster-Carr, part number 8516T83, which has the perfect outside diameter.  It needs about an inch trimmed off the inside.
At the top and bottom of the filters I added a flange with four ears.  One of these gets permanently attached to the 90 degree transition.  The other would go underneath the clean out box, or in my case right under the lower filter.  I think the clean out box is unnecessary.  The filters are hard to clean and to do it properly you need to take it apart and do it outside.  I had a really short box before but I would rather be able to take it apart and put it back together with less fuss.
The ears give a place for some long threaded rods to both squeeze the filters and gaskets together and run to the floor to support them at the same time.  First I did the top nuts, locked together, with the rods just touching the floor.
Then it's just a matter of tightening the nuts at the bottom until everything is snug.
Once they were tight and locked together I tapped in some wedges in case anything works loose.  So far it seems to seal fine.  The thicker and softer RG-13 gaskets would no doubt be more sure of getting a good seal but it just wouldn't work for me.  These gaskets are also cheaper, under $8 instead of $14.
1 hour ago, drzaius said:
Wow! That's a tight squeeze. Good solution though.
Yeah, I had to shoehorn that puppy in there.  It's more DC than I really needed for the space but I didn't want to be buying a third one later.  Had to make some compromises to make it work though.  Collection bin is pretty small, but I just added a third stage Thien baffle/trash can separator to the line going to the planer and that's the only thing that really makes a lot of volume of waste that is hooked up to it.
  • Who's Online   1 Member, 0 Anonymous, 43 Guests (See full list)
