Yesterday I just installed 2 Ring Spotlight Wired cameras and they literally took less than 10 minutes each to install and setup. They run on 2.4Ghz wifi and the camera on my front porch has RSSI of -47 which is very good. Amazon just had these for $170 which is $30 off the normal price.
https://shop.ring.com/collections/security-cams/products/spotlight-cam-wired?variant=56549570891
Ring has several different options for security cameras and I've read reviews that the power versions will record a bit earlier than the battery version. You can fully customize the motion zones with powered whereas you can only change the motion radius with the battery. That said if you can't run power then go with the battery (or solar). I went with security cam over doorbell since security has light and siren plus I could adjust the location and direction.
Here are some test videos I did yesterday. This is motion activated during daytime.
https://ring.com/share/6517683906149381767
This is motion activated using IR and the spotlight automatically activates.
https://ring.com/share/6517781522166085255
This is in the shop with the lights on.
https://ring.com/share/6517767155500486107
And shop IR motion detected.
https://ring.com/share/6517781122734132699
You get alerts on your devices whenever motion is detected and these cameras also have 2-way audio plus 110db siren you can activate. The first 30 days of cloud recording is free and after that it's $30/yr per camera or $100/yr for unlimited cameras which includes lifetime warranty and free theft replacement. I'll gladly per $100/yr for the convenience of not having to do anything about alerts and recordings.
Another plus with Ring is you can chat with them online 24/7 with any questions.
Now if you have power above the garage I would look at the floodlight cam there.
Lots of good info Bubba, thanks.
I've found this topic to be quite the wormhole!
I definitely like the battery option, that would make this incredibly easy, though probably not the most reliable option.
How is the sensitivity?  I imagine it would get pretty annoying getting alerts every time a car drives by the front of the house or the dog is in the back yard.
With the wired cam you have more control and can draw the areas for motion.
https://support.ring.com/hc/en-us/articles/115004189006-Utilizing-Motion-Zones-with-your-Spotlight-Cam-Wired
With the battery cam you can only adjust the distance.
https://support.ring.com/hc/en-us/articles/115005388123-Utilizing-Motion-Zones-with-your-Spotlight-Cam-Battery
  • Who's Online   0 Members, 0 Anonymous, 37 Guests (See full list)
    32k
    437.5k
    26,007
    FurniCore
    FurniCore
