Dolmetscher007 Posted February 22, 2018 Author Report Share Posted February 22, 2018 51 minutes ago, drzaius said: Which would have the effect of providing a much more robust corner that also be eased a little But... if you have a 3/4” butt joint, and you only cut away 1/4” to glue in a 1/4” x 1/4” strip of hardwood... you would not be covering the plys in at least one direction... right? Quote Link to comment Share on other sites More sharing options...
Woodenskye Posted February 22, 2018 Report Share Posted February 22, 2018 38 minutes ago, Dolmetscher007 said: But... if you have a 3/4” butt joint, and you only cut away 1/4” to glue in a 1/4” x 1/4” strip of hardwood... you would not be covering the plys in at least one direction... right? No you assemble the butt joint, the cut the rabbet. You will not see any of the ply. You are replacing the entire corner with the hardwood. Quote Link to comment Share on other sites More sharing options...
Woodenskye Posted February 22, 2018 Report Share Posted February 22, 2018 I went back to the beginning of this thread and was wondering if this is a table you built already and now others are looking for you to build again, how did you do it the first time? Why wouldn't it work this time? I still think my idea is sound from earlier and above but why reinvent the wheel. Quote Link to comment Share on other sites More sharing options...
