Problem with Epoxy
I was filling some hole in a lamination. Its salvaged pine boards with screw holes nail holes and a few knots. I poured the epoxy in and tried to break the bubbles with a heat gun. I have done this before and not had a problem.
I used West System with their slow dry hardener. I mixed it 2 parts rezin to 1 hardener. It went hard on me within what seemed like 10 to 15 minutes. i thought it should have taken longer to flash. It would up getting a pile of little white bubbles in it and I will have to grind it out now and refill it. Any tips you guys have would be much appreciated.
Two things come to mind.
1. Your mixing ratio is off - maybe. I haven't come across WS that uses 2:1. The 205 and 206 hardeners are 5:1 and 207 is 3:1
2. What did you mix it in? I've had WS go off and smoke in less than 10 mins using a disposable plastic cup. I've since gone to using shallow bowls (unless it's a small amount that I'll pour quickly).
Another thought is to find an epoxy that has a slower cure time (the above may be slow cure, I don't know). That way, the bubbles have time to gas off before set-up. Some of the golf shaft epoxy takes 24 hrs to fully cure. Those typically are mixed in equal parts and do come in black.
-Ace-
  • 2 months later...
One reason it might have cured faster than expected is the volume of epoxy in the holes vs on a flat surface. Curing epoxy is exothermic, it gives off heat. The thicker it is, the hotter it gets and the faster it cures. I was once woking out of a pie tin and left the remainder outside in the sun. I heard a loud bang. The epoxy in the tin had cured so fast it shattered. Yours cured too fast for the bubbles to escape. Use the slow hardener and thin a little within the permissable limit or find a cooler place to work.
Sent from my SM-G900V using Tapatalk
